Machines that you dont like
  • techsxge
    • Jan 2022
    • 660
    [Misc] Machines that you dont like
    I was just wondering after i saw a few people complaininga bout certain machines or techs who had problems with the same machines over and ver again:
    Which Machines do you not like at all and would you like to remove / replace as soon as you have the chance?
    I guess top 5 is the C3350i
  • Albonline
    • Sep 2008
    • 1151
    Re: Machines that you dont like
    3 most awful to work on were the royal 110,rbc1,and the 2020!, another nightmare the color7. compared to these the newer machines are easy, got to grin when i hear techs complaining about them.
    • techsxge
      • Jan 2022
      • 660
      i actually meant more recent machines, say something 2010 and younger
        • 14791
        Any that have manufacturers whose name starts with an X
        • tsbservice
          Field tech
          • 8020
          A4 KM models/derivatives. Every single A4 bizhub I worked on is worse than worst A3 bizhub I ever touched.
          • Hansoon
            • Sep 2007
            • 3389
            Going back a long time, for me the analog Minolta EP-4230 was the most idiotic construction. The development was done in the beginning by a German factory near Stuttgart called Develop. When Minolta acquired Develop they inherited the rotten design and were trying to improve it be redesigning it for over a year in Japan by using parts from the EP-4300. The result was still clunky. Replacing the paper feed rollers not alone was a nightmare. Customer could not remove himself, certain simple paper jams. A technician had to go there, removing guides and other stuff to reach the paper jam.
            Hans
            • wjurls
              • Feb 2017
              • 498
              Agreed, I only have one C3350i here and it's a pile of crap. Already needs new memory or MFP board. C8000 always makes me cringe as well.
              • allan
                RTFM!!
                • 5462
                Anything muratec... C25 is the worst.
                And anything running ink.
                Whatever
                • Albonline
                  • Sep 2008
                  • 1151
                  In that case the entire I series machines. flakey, and untested before release.
                  • mojorolla
                    The Wolf
                    • 2627
                    First gen Lexmark with constant 900 errors come to mind.
                      • 23009
                      It's another variation on Kyocera CF248 errors. Anything from a single document, a print driver setting, a browser based application, a firmware level, or non-print data can cause those errors. =^..^=
                      • adecanmin
                        • Oct 2010
                        • 316
                        I think the c3850 is worse than the c3851. So far I've had no touch screens go bad with the c3851. A bunch with the c3850. They are 500 new and unavailable. I've had to turn several into parts machines because I needed the screen
                        • allan
                          RTFM!!
                          • 5462
                          My fix for the the Bizhub A4 tragedy. Here have a C360 its for free. Don't have space? No problem it works just fine under a tree.
                          Whatever
                            • 23009
                            All you need is a long extension cord and a long network cable. =^..^=
                            • techsxge
                              • Jan 2022
                              • 660
