Biz hub c425
  • CopierChick
    • Aug 2012
    • 85
    Biz hub c425
    • 23010
    Re: Biz hub c425
    I did a quick Google search, and according to Google there is no model bizhub C425. Could it be a bizhub C452?
    That type of issue can occur if:
    *the black laser slit glass is dirty
    *the black laser optics are dirty
    *poor black developing
    *contaminated black primary charge
    I could be more specific if I had a valid model number to work with. =^..^=
    • allan
      RTFM!!
      • 5462
      Re: Biz hub c425
      Do a set of halftones at value of 125. Test do an internal test print. Like BC is asking. Whos saying was "have to pull teeth again"?
      Whatever
      • Ziggy
        • Feb 2018
        • 789
        Re: Biz hub c425
        which orientation is paper feeding? long or short edge feed ?
        • Synthohol
          Certified Konica Expert
          • 5864
          Re: Biz hub c425
          Clean the laser off with the wand.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4736
            Re: Biz hub c425
            Even though you mainly deal with Canon the least you could do it provide an accurate model #. Sorry I refuse to even try and help without some very basic information. Model #, Page count, Direction of paper, What you have done so far.....Not going to waste time anymore "interviewing" people who come here asking for help! It's bad enough I have to pull information from my customers all day not going to do it here.
            • techsxge
              • Jan 2022
              • 660
              Re: Biz hub c425
              I feel you brother...
              • CopierChick
                • Aug 2012
                • 85
                Re: Biz hub c452
                my apologies for making a flipping typo! Didn’t realize that could be so triggering for some people. Clearly it was a typo and it’s a C452.
                maybe next time you could get off that high horse of yours and just ask or feel free to keep scrolling ��
                • CopierChick
                  • Aug 2012
                  • 85
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4736
                    Re: Biz hub c452
                    A typo? The wrong model # is more than a typo. How about page count, direction of paper, what you have done so far, etc, etc?
                    Get off that low horse and provide correct information! It will help to get FREE accurate tech support on this forum instead of the same old guessing game!
                    Best of luck....
                    • tsbservice
                      Field tech
                      • 8031
                      Re: Biz hub c452
                      Best of luck....
                      I agree... it just doesn't feels right elite techs playing guess game based on few pictures sent from enduser.
                      • JasonSBE
                        • Apr 2014
                        • 187
                        Re: Biz hub c425
                        It's been a minute since I worked on a C452 so I may be getting it mixed up with the C451's but I do recall that sometimes the black developer can start to fail. This is usually indicated by a pooling of developer at the rear of the developing unit. I believe at one time there was a kit of seals you could order to fix the issue, but at this point I doubt they're available. I'd pull out the developer and see if that's what you're dealing with here. The images look like excess developer is spilling onto the print head. Not sure if that's the answer but hopefully it points you in the right direction.
                        • femaster
                          • May 2011
                          • 1514
                          Re: Biz hub c425
                          The was a big problem with the C451 (C550 and C650 also) that you are thinking of. Not that it never happened on the C452 model line, as I have had some there as well, but it was a lot less likely to happen. Still, definitely a good idea to check anyway with the age of the machine.
