C454e Light Copies, prints are fine
  • mrfuser
    • 1617
    Ok, cleaned white strip, replaced IU and DV assembly. Still copies very light. Not much difference in changing to different original settings.
    Any ideas?
    K
  • Ziggy
    • Feb 2018
    • 724
    Re: C454e Light Copies, prints are fine
    Any ideas?
    K
    If prints look good and the internal demo page is good then there is nothing wrong with Print head(laser) IU or DV assembly. When is the last time you cleaned the optics and both sides of the glass?
    • mrfuser
      • 1617
      [/QUOTE]
      • Ziggy
        • Feb 2018
        • 724
        [/QUOTE]
        What about the mirrors?
        • mrfuser
          • 1617
          Yep mirrors also. All optics cleaned
          What about the mirrors?[/QUOTE]
          • Ziggy
            • Feb 2018
            • 724
            [/QUOTE]
            If all optics clean and internal prints and print jobs look good you might have a bad ccd
            • femaster
              • May 2011
              • 1501
              I hate to ask the obvious, but have you run the gradation adjustments? Prints can look good and copies can look like crap if these get out of wack.
              You generally don't see that big of an issue with these models needing gradation run all that often. The ones we always had trouble with were the C227/C287, which would need to have the gradation run quite frequently to keep the copy and print quality looking good.
              • tsbservice
                Field tech
                • 8009
                Agree plus black & white bizhub 227/287/367.
                • mrfuser
                  • 1617
                  Swapped ccd and still poor. Ran gradation in service mode and in admin mode.
                  head scratcher this is
                  • mrfuser
                    • 1617
                    Ok replaced black drum and quality came back perfect for about 20 pages. Then started fading again!
                    any other ideas?
                    • mrfuser
                      • 1617
                      Ok replaced lamp assembly and ccd and black dv assembly, transfer belt and drum. Print is always great. If we scan letter R and have it rotate to letter it prints fine but if we scan letter to letter it is faded on non op side! This is really nuts! Anyone ever seen this??
                      • tsbservice
                        Field tech
                        • 8009
                        Clean Poly mirror.
                        • mrfuser
                          • 1617
                          remove the entire laser assembly?
                          QUOTE=tsbservice;2237452]Clean Poly mirror.[/QUOTE]
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4685
                            If prints are fine then you can rule out the laser. Just to be clear is light quality the same copying through feeder and if you place original on glass?
                            • mrfuser
                              • 1617
                              yes same
                              QUOTE=copyman;2237542]If prints are fine then you can rule out the laser. Just to be clear is light quality the same copying through feeder and if you place original on glass?[/QUOTE]
