Biz C3350 ADF rollers
  • copyman
    Owner / Technician
    • Sep 2005
    • 4643
    Anyone find a better solution for the ADF feed roller assembly? They are sold for around $160 which is crazy! I can buy whole low meter C3350's for $100 which I will do before paying that. Guess I'm asking if anyone found just the rollers that could be swapped out, maybe China aftermarket? I have several machines that are working by cleaning rollers but will need new rollers eventually.
  • copier tech
    • 8131
    Re: Biz C3350 ADF rollers
    I usually just clean these rollers even when worn they feed perfectly well. You can also 'rough them up' with some sand paper.
    I do however replace the separation pad.
    • adecanmin
      • Oct 2010
      • 296
      I use HP 4250 feed rollers. They are a little smaller widthwise but they are wider than the sep pad. I reuse the hub and slide the rubber portion over it. The rollers are about 5 dollars each.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4643
        Great! Exactly what I was looking for. I have plenty of HP 4250 rollers. Thanks!
        • wjurls
          • Feb 2017
          • 495
          $160?? Damn! Try here.
          Search results for: 'A3GNPP0100'
          • copyman
            Owner / Technician
            • Sep 2005
            • 4643
            Thanks for link.
            And precision roller also wants $60 for the sep pad! I guess PR are end user prices but still high even with my dealer discount. This is were most end users buy their parts then call saying "I bought the parts online, can you schedule a service call to install". Little do they know it would of cost them less for me to install my parts! Of course these aren't my regular accounts but new customers that get my info from internet.
            • wjurls
              • Feb 2017
              • 495
              Thanks for link.
              That's so aggravating. I try to explain that income from parts is a large part of my business model. If I don't have the parts income, then the labor rate will have to go much higher than it is. Most understand and will start sourcing most parts and supplies from me instead. It really doesn't cost them much more, sometimes even the same price to get them from me anyway.
              If you are a reseller, and buy enough from DCC they will give even better pricing then what's listed on the web. Same with ARC services in Burbank.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4643
                I've used both of the companies you suggested in the past. They are good just far from me here in NJ. It takes 5 days for shipping cross country.
                • wjurls
                  • Feb 2017
                  • 495
                  That blows. DCC is close enough for me to will call parts. ARC too but just a tad further.
