Biz C3351 fax?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Biz C3351 fax?
    Is it necessary to install the memory kit UK-211 when adding optional FK-517 fax kit to a C3351? I know with the older models you had to add memory.
  • Ziggy
    • Feb 2018
    • 802
    Re: Biz C3351 fax?
    Yes attached are the instructions
    • copyman
      Owner / Technician
      • Sep 2005
      • 4765
      Re: Biz C3351 fax?
      Thanks but I have the install instructions and looking at them made me ask the question. To me "When" makes me think it's not necessary but figured I would ask to be sure. Have customer that wants fax installed and I only have the fax no UK-211.
      <C3851FS/C3851/C3351>
      • When installing this option with Upgrade Kit
      UK-211, install UK-211 first.
      • rrrohan
        • Sep 2011
        • 1977
        Re: Biz C3351 fax?
        Dont u have any on 4 series copiers to steal it from?
        • B0265
          • Jan 2007
          • 718
          Re: Biz C3351 fax?
          No, you don't need the UK-211.
          • kingarthur
            • 1385
            Re: Biz C3351 fax?
            I don't think you need it either, looking at the installation guide, it's telling you that if you are fitting a UK-211, to fit it first, because the fax is installed above it .
            • copyman
              Owner / Technician
              • Sep 2005
              • 4765
              Re: Biz C3351 fax?
              Didn't know it's the same. Will check a few 4 series in shop. Thanks
              • emujo2
                • Mar 2017
                • 1579
                Re: Biz C3351 fax?
                And the winner is.............King Aurther!!!
                • femaster
                  • May 2011
                  • 1519
                  Re: Biz C3351 fax?
                  Install it without and test before fully reassembling. Worst that can happen is it will throw a code or not work at all, then you will know for sure. I see that the consensus is that it doesn't need it, and I would tend to agree that that, but again, you can test to be sure.
