Konica Minolta C284e will not read from front USB or add Movie Data
  • Synthohol
    Certified Konica Expert
    • 5824
    #16
    Re: Konica Minolta C284e will not read from front USB or add Movie Data
    heres a list of approved drives.
    • Steven S
      • Feb 2025
      • 2
      #17
      This may be your problem. I discovered that our Konica Minolta printer won't print from flash disks formatted with exFAT. They must be formatted with FAT32. exFAT is a more modern, improved version of the FAT family of multiplatform file transfer devices, such as flash disks or USB memory sticks. All FAT-formatted drives have inferior security and memory safety characteristics compared to modern file systems: NTFS for Windows PCs and APFS for Apple computers, but these file formats or systems are not multiplatform, so they are never used to format USB flash disks.
      • Ziggy
        • Feb 2018
        • 733
        #18
        See attached bulletin on how to get USB sticks to work with KM devices. You don't format with windows you use HPUSBDISK.exe
        • copier tech
          • 8144
          #19
          I have seen this bulletin but EVERY time I update a KM I format the USB stick in Windows & have NEVER had an issue.
          • Ziggy
            • Feb 2018
            • 733
            #20
            It doesn't happen often but sometimes formatting with Windows does make the USB stick not work on KM devices. If that happens following this bulletin will make the stick usable again. I speak from experiencing this.
            Edit to add the windows formatting became a problem when W10 first came out. They may have made changes in W10 to address this but it's good to have other options just in case.
