c458 Jamming from tray 1 only
  • acsolutions
    • Jun 2010
    • 519
    [Jamming] c458 Jamming from tray 1 only
    Hello, I think I just need confirmation on my direction. Will feed from drawers 2 and 3 but when I try to feed from tray 1 it will feed a single sheet fine then jam everything else after. Sometimes when i start a new job and it will jam the first page and so on. Usually it will feed a few inches out or get to the registration roller then jam. I replaced the feed assembly with the same result. My next step is to replace the drive assembly. I'm assuming the one way clutch or a belt is slipping. Anything additional would be appreciated. Thank
  • GIUBOSS
    • 1410
    Re: c458 Jamming from tray 1 only
    So you also replaced the magnetic clutch that drives the rubber rollers
    • kingarthur
      • 1341
      if you take out the paper feed unit, in the plastic of tray 2, there is a "spare" spring, it's not listed in the parts manual, but this is for thin paper, in the past, this has been swapped with the spring A161562800 on either tray 1 or 2, to prevent jam codes 10-02 and 20-02, the part number for the replacement "thin paper" spring is A161563000, it's not in any of the 8 series parts manuals, though it's definitely in the C258 paper feed unit, as I've just checked. if you have a C224(e) parts manual, you'll find it there, so you can see where it's located. if you have replaced the rollers and cleaned the needle bearings and it's still misfeeding - then I'd change this spring
      • femaster
        • May 2011
        • 1492
        There are no magnetic clutches in the tray 1 drive or feed units of the C458, unless you are referring to the registration rollers?
        • Gift
          • Mar 2011
          • 2459
          Not shure if the drive is designed like the iSeries machines wich had some issues with a so called "fast clutch" leading to jamming issues with tray 1.
          • acsolutions
            • Jun 2010
            • 519
            Yes,That's all part of the feed assembly.
            • acsolutions
              • Jun 2010
              • 519
              Basically the main drive drives tray1 and there are no clutches. I had a feeder assembly and swapped that out with same results. I guess the main drive is direct drive to tray.
                • 23003
                Do you have a jam code? =^..^=
                • tsbservice
                  Field tech
                  • 8002
                  Paper feed motor plus one-way in drive of tray 1
                  • Ziggy
                    • Feb 2018
                    • 710
                    I've had the bushings for the registration get gummed up and only cause jamming from tray one. I would take out registration assembly and clean the bushings.
                    • acsolutions
                      • Jun 2010
                      • 519
                      I'm going to take a drive assembly out with me but if that doesn't work I'll check that out. The only thing that makes me hesitant is that it sometimes gets to the registration roller and sometimes it doesn't. It usually jams after feeding an inch or it doesn't get much past the feed rollers. That's definitely something to remembe. Thanks
                      • acsolutions
                        • Jun 2010
                        • 519
                        The feed drive assembly worked. Thanks for all your assistance.
                          • 23003
                          Congratulations on your success! It would help me to know what jam codes you were experiencing. =^..^=
                          • acsolutions
                            • Jun 2010
                            • 519
                            I took it back to the store and disassembled, scored the shaft, Cleaned and lubed the shaft and bearing, reassembled and installed in the machine I pulled the part from. I ran several hundred copies without a flaw. The bearing and shaft were all gummed up that was the issue. Yeah I wish I thought about getting that jam code that could have been helpful to the next guy! Sorry
                            • FuserNoob
                              Service Mgr, CISSP
                              • Jul 2022
                              • 149
                              I have a C458 and was giving a 20-02 error on tray 2 - I replaced the pickup/feed rollers, no go, clutches and torque limiter, no go, replaced mag clutch, no go, replaced the spring as described above and DING, we have a winner!
                              THANKS!
