C1060 Error code- C4641
  • wjurls
    • Feb 2017
    • 494
    #31
    Re: C1060 Error code- C4641
    Originally posted by Yanouch29
    ok,
    what is : "Bare developing sleeve" (i'm french and my english is bad...)
    Yes, that's what I'm going to do, (but not for the dust filter that has never been replaced by Konica for 7 years!)
    I now know how to get into the technical mode on the machine (we press info counter when you start it) and I know that the Konica technician made settings when he replaced a development unit or a drum
    Do you know the adjustment procedure?
    (I can take pictures of the screen on my machine)
    Bare roller means we can see the developer sleeve and it has no developer on it. You should only see the developer "brush" and not the metal sleeve itself.
    I would suggest having your tech replace the parts for you.
    • Yanouch29
      • Sep 2023
      • 31
      #32
      hello !
      The Konica technician has passed and he changed the yellow developer block.
      The machine operated for 30 minutes and it redo the same defect as before but without error code this time!
      It works well at the beginning and after 12 leaves about the yellow disappears from half the leaf, leaving just a few fine vertical strips on the other half of the sheet.
      If I print a test page with yellow in technical mode it works very well!
      I recalled the technician who told me that it was little electronic problem (high voltage card at the back of the engine)
      I am very embedded because time passes and here is already 12 days of production stop.
      Finally I print 12 leaves by 12 leaves and I let it stand ... it's hell!
      If someone has an idea...
      • Yanouch29
        • Sep 2023
        • 31
        #33
        Good morning,
        Thank you all for your help !
        I almost solved the problem. For yellow it is finished:
        The upper tension bar of the belt was only attached on one side and hanged on the roll of yellow !!!
        I redid a part to maintain it and now I have no more default on yellow!
        I still have this to be resolved: I have small spots that have appeared in printing (on white paper) since I put the roll (it is repeated every 9.5cm).
        I think that the belt scraper is no longer doing its job because there is a lot of dirt stuck behind the upper tension roller (we see them by TrensPance on the belt) and therefore the belt is not perfectly flat.
        I ordered a new complete belt but I would like to save this one. How to dismantle this belt?
        I already know that it is necessary to put calls to relax it, but is there a technical manual where the method is explained?
        THANKS.
        • Synthohol
          Certified Konica Expert
          • Mar 2016
          • 5799
          #34
          hope you ordered a new cleaning unit too and not just the belt.
          btw, if you become a contributor i can send you the full service manual.
          • Yanouch29
            • Sep 2023
            • 31
            #35
            thanks a lot for the document !
            How does we become a contributor?
            I have read in the technical manual that the belt cleaning unit has toner, this toner is a special toner. Yesterday I spilled this toner in the trash because I thought it was only waste. He has to stay a little ...
            But the machine should fill it again with its cleaning process?
            Or do I have to change the cleaning unit?
            I ask this question because I will receive a new transfer belt on Monday and a new cleaning unit.
            But I'm formed on the old to become a technician ...
            • Yanouch29
              • Sep 2023
              • 31
              #36
              i'm a new contributor and now a very little technician...
              if you have the full technical manuel for a C1060 Bizub press, i'm happy...
              in french language ? (but if it's in english is ok too... )
              • Yanouch29
                • Sep 2023
                • 31
                #37
                Good morning,
                Just to say that everything is back to normal!
                Thank you to everyone for the manual and the advice.
                I replaced the entire transfer belt mechanism with a new one! With a new cleaning unit. It was not too difficult ... I took the opportunity to dismantle the old belt to neat its rolls which were very dirty because of the defective plastic scraper (damaged itself by the tensioner roller which had fallen on it for a long period).
                Do you know if we can just change the two plastic rucker blades and their support?
                To relax the belt I used two small screws to block the tensioner of the upper roller because I do not have the wedges provided for that.
                The belt is not easy to get out because it hangs everywhere.
                It is quite worn out and I think I will buy one quickly before it is no longer available.
                the little part i have made to hold the roll !
                swett dreams...
                Do you know how to control a development unit (knowing so electrically it works?) I have 4 or 5 of which the developer is dead ... I would like to neaty them and give them new development, but for that it is necessary to me Ensure that they work!
                • Synthohol
                  • Mar 2016
                  • 5799
                  #38
                  um, every orange piece on that is PACKING MATERIAL and must be removed before installing.
                  i think im tripping...is this REAL LIFE?
                  IS THIS A JOKE?
                  in case this is real, you are inadvertently gonna wreck that 100000 dollar machine.
                  this hurts to watch.
                  those orange tabs PREVENT the rollers from doing their job.
                  please call a qualified tech.
                  • Yanouch29
                    • Sep 2023
                    • 31
                    #39
                    yes I know !!!
                    There are also two other small screws to remove which block the tension and which allow the belt to be tense during transport.
                    In the photo it is not the belt that I installed but the old belt that I put in the closet!
                    I put the Orange wedges back because I saw that the new one was delivered like that.
                    So if I have to move it it will be safe!
                    The new one is in the machine and works very well!
                    • Synthohol
                      • Mar 2016
                      • 5799
                      #40
                      thanks for that, i was really worried, ive seen plenty of newb repairs and i was concerned.
                      its a very expensive machine to just "try" and maintain, a lot of finesse is needed and im glad that was just your storage option.
                      hope you arent mad over the misunderstanding, i just honestly got scared for you.
                      also sent you a pm.
                      I didnt see you contributed, i was out of state, my mom died last week..
                      sorry for the delay.
                      • Larhal
                        • 552
                        #41
                        also sent you a pm.
                        Sorry to hear that. Thoughts are with you.
                        Larhal
                        If all else fails read the Service Manual!
                        If that fails, meet me at the pub and we will discuss it.
                        • Yanouch29
                          • Sep 2023
                          • 31
                          #42
                          also sent you a pm.
                          thank you for your comeback, Do not be worried,
                          I carefully read the technical manual you sent me.
                          My machine is worth only $ 1000 ... It is my main work tools and even if I am not yet very experienced I managed to make it work again. And it's a bit thanks to you!!
                          So take care of yourself!
                          I wish you a good evening
                          • Yanouch29
                            • Sep 2023
                            • 31
                            #43
                            Good morning,
                            I have a new problem with my machine.
                            The EFI IC-415 print controller no longer works.
                            it shows 00 on the display and the printer tells me that the controller is not connected.
                            it “beeps” 5 times displaying: d6
                            then it displays I believe: 62
                            and finally: 00
                            This isn't the first time he's done this and I think we need to change the hard drive... but I don't have the installation files!
                            do you have an idea ? documentation on the IC-415?
                            THANKS
                            • Synthohol
                              • Mar 2016
                              • 5799
                              #44
                              was remote desktop ever enabled?
                              what do you see when you log into the fiery via browser?
                              • DeWalt_Man
                                • Jul 2023
                                • 21
                                #45
                                I think I would start with (4) primary transfer rollers, the transfer belt, and a transfer cleaning assembly.
                                I must warn you, though, that this is not a job I would send an amateur to do. If it's your first time changing a transfer belt, there's a 50/50 chance the new belt will be noticeably damaged by the time you get it re-assembled. =^..^=
                                as a semi-experianced engineer, i second this, i still ruin 1/4 of the belts i do
                                worst repair i can think of doing
