C558 copy quality
  • honest12345
    • Sep 2023
    • 1
    C558 copy quality
    SKM_55823091815080.pdfIt is giving me copy's with black dots all over the the paper
    i have changed the print head changed the drums changed the High voltage unit
    please assist me on this problem
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: C558 copy quality
    please assist us by posting a full size sample.
    • tsbservice
      Field tech
      • 8013
      Originally posted by honest12345
      [ATTACH]59721[/ATTACH]It is giving me copy's with black dots all over the the paper
      To start with you have color registration problem. What are voltages in state confirmation?
      • Synthohol
        • 5824
        as with any CQ issue, try printing the halftones, look for a repeating pattern.
        at first glance to me it looks like DV in the charge roller but cant tell if it repeats or the feed direction.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4700
          Replace K developer unit and make sure using "genuine" toner
          • Cantechman
            • Nov 2008
            • 228
            Replace the 2nd image transfer roller, I have had that problem in the past and that corrected it.
            • Ziggy
              • Feb 2018
              • 732
              there is a slim chance it could be fuser. Stop the print job before it finishes and check transfer belt to see if it has the spots. then take a look at image on paper before it goes through fuser
                • 23008
                I'm probably reading it wrong, but the speckles that I see are all clustered around the text. Is that what you mean? =^..^=
                • Oystercopy
                  • Oct 2009
                  • 623
                  Generic toner? I know someone else mentioned it, but thought I'd reiterate.
                  OC
                  • copier tech
                    • 8144
                    Are you using genuine Konica Minolta toner & drums ?
                    • Synthohol
                      • 5824
                      *crickets*
