Bizhub 350 - Multiple issues
  • GinaTallmanCPA
    • Jan 2024
    • 18
    #46
    Originally posted by Synthohol
    should show on a network config page?
    Well it is currently in the back of someone's truck waiting to be recycled, so can't run one. The copier place will know.
    • femaster
      • May 2011
      • 1519
      #47
      Originally posted by GinaTallmanCPA
      Thanks! I wonder if it even has a hard drive...
      I would be very surprised if that machine has a hard drive installed. We had hundreds of those out in the field and almost none of them had it installed. If it is installed, they can remove it and odds are you would never even know it was missing.
      • Synthohol
        Certified Konica Expert
        • 5888
        #48
        unless you try to fax ๐Ÿ˜‰
        • tsbservice
          Field tech
          • 8049
          #49
          WTF...who the fax today ๐Ÿ˜ƒ
          • femaster
            • May 2011
            • 1519
            #50
            We had a lot of those out in the field with faxes, and I don't recall any of them having a hard drive.
            ๐Ÿค” I just looked through the Configuration Guide for the 200/250/350 and in there it indicates the only thing required for faxing is a 32MB memory expansion, which the fax kit comes with. Looking at the HDD (40GB) option in the guide, it states that it is required for Scan-to-HDD, Image Setting functions, and to program up to 5 additional Copy Jobs. It also recommends the 32MB memory expansion be installed to optimize system performance. No mention of a requirement for faxing, so I don't think it was needed for the function.
            • Synthohol
              • 5888
              #51
              its how i (mis)read the footnote, might have been the 3 series slower machines didnt have a hdd and it was needed for scanning and /or memory faxing because the 40ppm and faster had a hdd from factory.
              i cant have lost all my marbles yet?
              • femaster
                • May 2011
                • 1519
                #52
                That's a very good possibility. I know the HDD was optional in the 22 and 28ppm models, standard in the 36 and 42ppm.
                  • 23010
                  #53
                  Most of mine did not have hard drives. I would be very surprised if yours did. Good luck acquiring your baby. =^..^=
                  • GinaTallmanCPA
                    • Jan 2024
                    • 18
                    #54
                    The IRS does ๐Ÿ˜‚ but we use e-fax for that
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4756
                      #55
                      Yes, I also remember most of those machines I worked on didn't have HDD. I installed many fax units in those models and only had to add additional memory stick to MFB board. Again the HDD was added mostly for scanning large jobs.
                      Speaking of fax in that model, we had so many fax issues when VoIP came out.
                      Wasn't a bad mono model for back then. Ran drum to drum with no calls in between.
