I series premature fuser failure
  • Konicatech
    • Feb 2016
    • 131
    I have changed countless fusing units on these machines (c250i and c300i) all because the toner was rubbing off the page.
    Anyone else experiencing this? If so do you have a fix rather than replace the fuser?
    I have tried bumping the temp up by 10 deg which sometimes works for a while and others it doesn't.
    Know someone mentioned fuser smart control before but don't know what that does exactly so have left it alone.
    Seems like these units fail randomly, 50k or 300k who knows..
  • KMFLT3CH
    • May 2017
    • 241
    Re: I series premature fuser failure
    Depends on if you're using genuine toner or aftermarket. I've had dozens of i-series fusers fail prematurely even with genuine toner. If toner smears off the page I do the following first:
    Disable smart fusing control
    Increased fusing temp +10 across the board
    Set fusing transport speed to 0
    That works about 50% of the time, you might get another 6 months out of the fuser. If it still smears toner after those settings, replacing the fuser fixes it.
    However I've had a couple instances where the customer was using bad toner and was still seeing terrible fusing issues after all the above settings and a new fuser.
    Finally replaced DV unit, vacuumed sub hopper of Katun toner and put a genuine Konica toner in device and have not returned since. Only seen this twice, majority of the time it's just crap fusers that don't make yield.
    • Radiscar
      • Jun 2019
      • 74
      To prevent issues I've change the sleep/energy savings and tried to manage poor power with power filters but I've never had to replace a konica fuser yet due to toner not setting -bearings making noise or scratches get them first -they start to jam/wrinkle paper before anything else.
      1
      Paper Setting The paper to be used for printing does not match the paper type and size of paper setting selected on the machine.
      YES
      Make the paper setting again on the machine.
      2
      Image check: Poor fusing performance
      • Select [Service Mode] -> [Test Mode] -> [Halftone Pattern].
        Select "SINGLE", "HYPER", "Error diffusion", "1-Sided", "Black(1PC)", and "Full Bleed", enter "64" for Density, and load tray 2 with A3 paper. Press the start key. This runs a print cycle.
      • Check the image after printing and the abnormal image is evident.
      YES
      Go to the next step.
      3
      • Select [Service Mode] -> [System 2] -> [Smart Fusing Control] and select [Prohibit].
      YES
      Return the setting to the original one and go to the next step.
      4
      Image check: Offset
      • Select [Service Mode] -> [Test Mode] -> [Gradation Pattern].
        Select "SINGLE", "HYPER", "Error diffusion", "1-Sided", "8 Color", "Front Half", and "12 gradations", and load tray 2 with A3 paper. Press the start key. This runs a print cycle.
      YES
      5
      Service Mode -> Fusing Temperature Select [Service Mode] -> [Machine] -> [Fusing Temperature] and make the necessary adjustment, and the image trouble is eliminated.
      * Poor fusing performance: Decrease the setting value
      * Offset: Increase or decrease the setting value
      NO
      Return the setting value to the original one and go to the next step.
      6
      Fusing unit There is dirty or foreign matter on paper path of fusing unit.
      YES
      Clean. (Disassembling the fusing unit is prohibited.)
      7
      Fusing unit Scratches on belt or roller in fusing unit.
      YES
      Replace the fusing unit.
      NO
      Replace the power supply of fusing.
      • avecosat
        • Jun 2012
        • 305
        +1 and I have a similar problem in 8 series
        • tsbservice
          Field tech
          • 8020
          Interesting
          • Gift
            • Mar 2011
            • 2459
            Interesting
            Yeah that's funny^^
            • kingarthur
              • 1369
              We've stopped using aftermarket K toners for C450i series, as it's causing problems. the suppliers of that toner said to reduce fuser temp by -20, fuser speed by -20, set warm up to mode 4 - it helps a little, but some still have problems. it only seems to be K toner
              • KMFLT3CH
                • May 2017
                • 241
                Interesting
                Yeah that is odd, I am seeing the opposite in the service manual. I've personally tried -20 and it was worse than +10
                • tsbservice
                  Field tech
                  • 8020
                  [ATTACH=CONFIG]61316[/ATTACH]
                  I think SM is messed
                  From same manual came this:
                  • KMFLT3CH
                    • May 2017
                    • 241
                    Now that is funny!
                    • tsbservice
                      Field tech
                      • 8020
                      This came from cra*p heating roller temperature sensor(TEMS) Konica put in fusers. They said to replace fuser
                      BTW there is new fusing unit for Eagle 2.
                      • SmellsHot
                        Head Tech
                        • 512
                        We've had quite a few of them with this issue. Most of the time the fuser fixes the issue, but we've had a handful where just the top and bottom inch of the paper won't fuse and ended up having to replace the expansion control board. You can watch the temp on the outer edge fall well below value when testing. I series have been a big issue for us lately.....damn quality control during the backorder pandemic
                        Everyone has the right to be stupid. Some people just abuse this privelage more than others
                        • femaster
                          • May 2011
                          • 1513
                          There is a previous thread on the subject here that you can skim through:
                          C250i fusing problem
                          Check out my post in the thread here which has a few bulletins on the subject:
                          https://www.copytechnet.com/forums/k...ml#post2504035
                          • tsbservice
                            Field tech
                            • 8020
                            Now that is funny!
                            Traced manuals back to 4e - same mistake
                            • 4Toon
                              • Mar 2023
                              • 112
                              Engine Sw have things to try if you want. The way the manual read is No. 6 SW should be set to "on" if you are not in japan but then talks about EU so not 100% on that. I like SW 26, if that does not work 44 and 57 could be tried. Also 24 but would change the sleep timer customer might not like that and chances of noises on that one.
                              Permanently banned from Konica SSD.
