C6500 error code c-3906
  • theprinter
    Hi guys!
    I am an operator and my machine recently brought up the error c-3906 during warmup, turned the machine on and it begins to warm up and then brings up the code. please help if you can.
    thank you
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    Konica Minolta - Bizhub Pro C6500 - Error SC-3906
    Cause: Fusin low temperature hardware detection abnormality. Temperature Sensor/4 (TEMS/4) detected abnormality signal continuously for the specified time.
    If you has operator, contact a KM Technician, to solve this.
    Then need reset DipSW 3-1.
    • theprinter
      /thanks for that, do I need to set dipsw 3-1 to on or off
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        Turn it off.
        ---Groucho Marx
        • jma676
          Expert Tech
          • Mar 2009
          • 323
          -----------------------------------------0=Off---------------------------------------------------
          • nullskull
            Learning
            • Aug 2023
            • 469
            Hey I have this same issue on a 1250p would replacing any parts help with this?
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5875
              does it come right back after setting dip sw 3-1 to 0?
              • nullskull
                Learning
                • Aug 2023
                • 469
                Mine will return anywhere from 20 min to an hour after the dip sw is reset. Someone suggested it might be a voltage issue from the wall.
                • Ziggy
                  • Feb 2018
                  • 790
                  Looking in service manual the first thing I would check is the lamps
                  C-3906 Classification Main body: Fusing sensor abnormality Cause Fusing temperature sensor/4 (TH4): temperature abnormality (Hard)
                  TH4 detects the fusing abnormality detection 6. Measures to take when alert occurs The main body and the option stop immediately. Estimated abnormal parts
                  • Fusing temperature sensor/4 (TH4)
                  • Fusing heater lamp /3 (L3)
                  • Printer control board (PRCB)
                  • AC drive board (ACDB)
                  Correction Be sure to change the software DIPSW3-1 from 1 to 0 and turn OFF/ON the sub power switch (SW2) of the main body after fixing the defective parts.
                  Note
                  • If DIPSW3-1 is set to 0 before defective parts are fixed, it may cause fire.
                  • wjurls
                    • Feb 2017
                    • 498
                    TH 4 Can get pretty gooped up and torn. I would suggest going in and replacing TH4. While in there, replace the auxiliary roller and it's related bushings and bearing as well as the cleaning sheet.
