C224e/C284e/C364e/C454e/C545e cyan dev unit problems
  • Don N.
    • Nov 2011
    • 409
    #226
    Re: C224e/C284e/C364e/C454e/C545e cyan dev unit problems
    Originally posted by M1963
    Don N.
    you stated: After switching to KTN toners, our excess toner was reduced as well as the false C2552,4,6,8 High Toner TCR % codes.
    do you have your opinion why the error C2552 TCR>10% sometimes appears, the machine solves the problem by itself and works normally for a while.
    Assuming a poor mixture of developer content in the toner. We remive the offending toner, vacuum out the hopper & replace with Ktn toner. Do a hopper fill & run about 20 halftones at full density (255) then "manual" add toner cycle. TCR always comes back down to around 6.5%. Had to give up on another brand due to some batches of this. Mainly black & cyan.
