C224e/C284e/C364e/C454e/C545e cyan dev unit problems
  • Bob Wescott
    • Sep 2013
    • 14
    #136
    Re: C224e/C284e/C364e/C454e/C545e cyan dev unit problems
    Originally posted by AjitN
    Pls see my previous statement. we are using C8000 toner without any problem, sometimes we add C8000 developer in toner bottle, but such cases are very rear. I am not suggesting to use C8000 toner for long run, but just to isolate the problem. Why we could not think of it could be manufacturing defect from KM plant. This we have observed such failure wrt xerox developer. Just try for few thousand prints to confirm, as it is cyan dev are failing so whats a big deal in trying.
    Here's my crucial question: Has anyone used a compatible DEVELOPER product in a C364 or the like? Are any of them any good? Replacing cyan developer assemblies is awfully costly. We use oem all the way but have obtained maybe a month's use before the developer is half gove again. We bought this unit used with only 100k but some idiot had vacuumed out all 4 developers before returning it to the leasing company. We obtained a set of developers from another relatively young machine and everything was fine until the cyan screwed up, and it has done so now for the 3rd time. We think an HVT board may need replacing but we also have to replace the developer when we do. Does that sound right?
      • 14890
      #137
      Originally posted by Bob Wescott
      I think that the black is the only developer that gets replenished this way.
      On the 4 and 4e series, all four dev units get replenished with developer in the toners.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        #138
        Our standard procedure is now to replace the drum, developer and toner with vacuumed hopper at the same time and the problem has still not repeated on any machines with this issue since doing this. I'm 100% convinced its defective toner or settled and separated developer / toner mix in bottle not being shaken enough / at all by customer before install.
        • fishleg
          • Mar 2009
          • 426
          #139
          Its either cheap toner or a bad drum. I know I had one where the black had been sucked dry, drum looked fine but to be sure I swapped M and K drums next day customer reported M grit on paper. I dont really understand how a drum can start sucking dev if it looks perfectly fine with no scratches or visible wear. Can anyone else explain this?
          Sent from my D6603 using Tapatalk
          • hotfuser
            • 180
            #140
            i have heard through a good source that this has been an issue for quite a while.
            it seems to be a problem with the drum lifes.
            while there is no issues with copy quality and how many copies it seems to be the amount of minutes the drums are doing ecspecially the black drum.
            i have C224e go for a year to 18 months with out a problem or even a call and all of a sudden the cyan dev unit has been completely drained.
            the drum minute life seems to be the problem as after replacing the drums i have had far fewer failures than i have had previously.
            let me know your thoughts.
            • Tech Helpdesk
              • Jul 2015
              • 112
              #141
              Hi mate,
              This is what we have been doing and so far all is well.
              1 โ€“ Print off management lists before and after work and also print off halftones at 128 and 200 and check the quality.
              2 โ€“ Check / change and reset every drum at 100 โ€“ 130% to return voltage correction levels to normal state.
              3 โ€“ Check the condition of the transfer belt and replace at 100-130% and clean the IDC sensors
              4 โ€“ Check and return to factory defaults (if req) โ€“ D Max Image Density, TCR Level setting, Image Background Voltage Adjustment, Transfer Output Fine Adjustment, etc.
              5 โ€“ Check the TCR values on each colour they should be around 6.5% if not tone up manually.
              6 โ€“ If the developer units are over-life and the print quality is ok then reset the units using the developer reset tool.
              7 โ€“ Initialize and Stabilize the machine, then Gradation Adjust(minimum 3 times each for print and copy) and ensure the convergence values are 60 or less on both)
              8 โ€“ Obtain final management lists and halftone prints to confirm quality.
              Regards
              • minimerlin
                • 851
                #142
                Well greetings...I have just joined the Cyan Dev Unit Failure Group! Last month I replaced a cyan dev unit for depletion but with all readings as normal! Machine only done 1k colour since then and today back to machine..again cyan dev depleted..not spillt. Drum lives just expired. Toner replenishment is working and all shutters working. Ordering new dev tank and replaced cyan drum. Will renew all colour drums on rtf call for dev tank. I hope this does not mean the start of our epidemic!
                Please do not PM me without asking first.
                • hotfuser
                  • 180
                  #143
                  replace the drums as this seems to be the solution.
                  i started this thread a while ago now and i have only just seem to have got to the bottom of this.
                  it seems to be the drum life is causing the issue. as i have had machines go 18 months to 2 years and the first problem that happened was cyan dev depletion.
                  replacing drums if the minutes are well over life has seemed to have culled the problem so far.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    #144
                    that wasn't the case for me as i was putting a new drum in each time i was changing the cyan dev unit. as on each failure the charge unit was again full of cyan toner.
                    • hotfuser
                      • 180
                      #145
                      it was the black drum mainly that seemed to be causing the issue
                      • hotfuser
                        • 180
                        #146
                        quieting down now as changing the black drum has slowed the issue.
                        if the minutes on th k drum are double change it as it will save in the long run :-)
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2139
                          #147
                          This doesn't reflect my experience.
                          All our e series machines are sent out setup for life extension on all consumables, all drums routinely run over life non stop. (to my disgust) I've had black drums so worn out they start making black lines down the prints, still with no consequences to the colour parts.
                          This non e series machine I wrote about is the only one I've experienced this on to date and its black drum was near new during the problems.
                          What ever it was doesn't seem to be happening anymore.
                          • giddyupngo
                            • Oct 2014
                            • 109
                            #148
                            I know this is an old thread, but I have had a couple machines mis-reporting TCR levels, where they drift low (usually) in just one color. Our theory is that toner mist or toner spills get to the Front side board (that the developers plug into) and short it out/damage it. We typically put a meter on the developer connector (while machine is on and door/waste toner sensors appropriately tricked) and measure the voltages on the pins. If the voltages on the problem color seem to match the working color, but the TCR level is a few percent off, we conclude that the front side board is shot. Replacing it has worked fine so far. You can buy some time with manual toner adds, but the TCR will typically drift off again without board replacement.
                            • femaster
                              • May 2011
                              • 1514
                              #149
                              Just a side note, I have not read the entire thread, so maybe others have experienced my current situation...
                              I have yet to have any issues with drained cyan dev units to date, but I did have an issue this past week with a cyan dev unit that had leaked developer out the back of it on a C454e. The customer was running a large set of color brochures and everything went "pink" on them. Upon testing, there was no cyan output at all. Removed everything and found that the drive gears on the dev unit were covered in toner/developer and were worn down to nothing, and there was a small pile of developer in the back of copier. Dev unit was at 47% used. Checked all the other dev units and they were all clean with no problems.
                              • copier tech
                                • 8192
                                #150
                                This bulletin was recently released.
                                It basically says not to let ANY unit run over life & keep the FW up to date.
                                Most of my Bizhub users have high expectations so I replace all units before they cause a print quality issue, hence I rarely see this issue.
                                Failure of Image Unit or Developer Unit 2017.pdf
                                โ€‹
