C224e/C284e/C364e/C454e/C545e cyan dev unit problems
  • PeterG
    • Jul 2008
    • 177
    #61
    Re: C224e/C284e/C364e/C454e/C545e cyan dev unit problems
    Left field, but. how about when it is dumping, carefully swap the cyan & magenta devs. (After covering the toner inlets)
    Should let you know if it is dev or hv.
    • UKTeam
      • 24
      #62
      Hi - its been years since I posted here or at d-net - Long time reader of both sites, most days still!
      (Nearly 30 years Konica/Kyocera tech)
      This thread reminded me of something which you might find interesting about the Original Toner, which naturally I want see used.
      I have only had this problem when running original. (many don't, not by my choice)
      TNBT1400371EN - Dev added to toner 222e.pdf
      This is probably irrelevant, unless in circumstances where extremely High Toner coverage is constantly printed, causing high replenishing..?
      Could this be overloading the units with Developer and causing the overspill?
      Thought I would just contribute this...
      • hotfuser
        • 180
        #63
        [ATTACH]29326[/ATTACH]
        Very interesting UKTeam. Thank you for that information. When was that bulletin released if you that info?
        • UKTeam
          • 24
          #64
          October 2014 is the date I obtained it....
          • hotfuser
            • 180
            #65
            Many thanks
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              #66
              Precisely 6000 colour pages printed since last failure.
              cyan corkscrew patterns again, cyan drum charge grid contaminated, developer and toner stains at edge of top side of drum cartridge where its been tracking into the waste section.
              Time to try the HV board me thinks.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                #67
                I blew out the 6k old drum and had it installed for the new dev to run up after installing the new hv board.
                the grid was contaminated yet again on completion and the mylar below the dev roller was totally covered in cyan toner.
                After running some tests I cleaned the dev unit before installing the new drum and run some more tests afterwards. Thankfully everything stayed clean from then on. Starting to think this might be a transportation issue. Again just like the last one the dev was piled at one end out of the box and very difficult to start turning to correct this. This was fresh out of the warehouse yesterday.
                • hotfuser
                  • 180
                  #68
                  have had another 4 units fail this week. The units are still failing between 50-80k. Two of the copiers this week have been in the customers for over a year with no problems then BANG this happens.
                  I still can not beleive this is not a more common problem through out the industry. It seem s that i am the only person that is having this issue on a major scale.
                  If the copier would be failing within weeks i would say i am doing something wrong but after a year to 18 months then no.
                  I am also confused as to why it is only the CYAN dev unit that is having the issues.
                  Oh well onwards and upwards we will get there in the end.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    #69
                    I THINK we have a new c364e machine also destroying cyan dev units it already failed 2 weeks ago. Will know more on Monday, I think it's failed again. I'd be happier getting 80k, i cant even get 10k at the moment.
                    • barber782
                      • Aug 2011
                      • 281
                      #70
                      Seems to be two types of fault arround on these machines.
                      The dev draining one and a c255* error code which is related to the toner sub hopper assembly gears.
                      • hotfuser
                        • 180
                        #71
                        yes correct the one that is causing most issue is the dev unit draining for no apparent reasoning.
                        No codes and all levels are correct this is the most concerning one.
                        • PeterG
                          • Jul 2008
                          • 177
                          #72
                          I reckon you could be onto something. I have maybe a 100 of these machines in the field & have never had a Cyan dev failure. I have however had about a 10% failure in the sub hopper assy.
                          Is it possible that here in Australia we have had a different batch of devs supplied?
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            #73
                            Dont know if the actual dev is different but i know KM region lock consumables.
                            C360 series devs also come in a similar state and i always correct them by manually agitating to get rid of the pile too. I think in the hundreds if not thousands of times I've worked on a c360 series machine, I have only seen a stripped developer once. For all their crappiness in tray one and two paper feed units they have to be one of the most reliable machines ever to of been built. Though getting a little old and crusty now and the odd one is starting to fail electrically.
                            • AjitN
                              • Mar 2009
                              • 287
                              #74
                              why we are not trying different toner, I think it is manufacturing defect which KM will never accept.
                              Please try another toner
                              say C8000 tomer is good for C224 / C220 series.
                              Although it does does not contained developer it can be used for isolating problem.
                              we are using C8000 toner regularly without any problem, when dev level goes down(for 224 series, C220 as it does not contain dev for CMY ) after 100/150 K we add up with C8000 developer without any problem.
                              I do not know but this could be best solution and also it is very profitable as toner is cheap gets refilled three times in one set.
                              Hope this helps.
                              Ajit
                              • AjitN
                                • Mar 2009
                                • 287
                                #75
                                no feedback or any comment
                                surprising
                                what I said
                                If it works its miracle
                                AjitN
