C224e/C284e/C364e/C454e/C545e cyan dev unit problems
  • hotfuser
    • 180
    #91
    Re: C224e/C284e/C364e/C454e/C545e cyan dev unit problems
    Guess what ?
    i have had another 3 cyan dev units fail this week.
    All failing once again between 60k-90k colour.
    The one i have had this morning is a C284e which has been in the customer for nearly two years without a problem (maybe the odd jamming issue or a worn black drum unit) then out of the blue (no pun intended) the cyan dev unit has failed.
    Will be going back to take it back to factory settings after replacing the unit.
    Will keep you all informed.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      #92
      Have you had any initialised machines re-fail since doing so ?
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        #93
        One thing I have noticed on the c454/554 machines with the toner filter is that the filter is almost always blue when ready to be changed.
        I think these machines may just be a modern C352 where regular (IU) failure in certain environments is just to be expected and dealt with. At least it will keep us employed...
        • hotfuser
          • 180
          #94
          None as yet have failed since factory re-setting and re-firmwaring.
          I will let you know whether this does happen
          • hotfuser
            • 180
            #95
            Another failure this morning. Copier had been in customers 14 months and its first breakdown call was this morning for PCQ and yes the cyan dev unit failed.
            The copier has done 61k colour and 197k black.
            oh well that is another to add to the ever increasing pile.
            • copier tech
              • 8188
              #96
              Failure of Image Unit or Developer Unit.pdf
              Not sure if you guys have seen this TAD from March this year regarding dev loss?
              โ€‹
              • hotfuser
                • 180
                #97
                [ATTACH]29658[/ATTACH]
                Yes had that bulletin thank you. That basically is for machines that have done over life all of my machines are no where near life on their parts.
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  #98
                  very interesting document none the less.
                  • chinxxx
                    • Jun 2015
                    • 35
                    #99
                    Thanks, in advance, for any info.
                    เธฃเธนเน‰เธฅเธถเธ เธฃเธนเน‰เธˆเธฃเธดเธ‡เน€เธฃเธทเนˆเธญเธ‡ เธงเธดเน€เธ„เธฃเธฒเธฐเธซเนŒเนเธกเนˆเธ™ เน€เธฃเธทเนˆเธญเธ‡เธŸเธธเธ•เธšเธญเธฅเธ—เธตเนˆเธ™เธตเนˆเธ—เธตเนˆเน€เธ”เธตเธขเธง เธงเธดเน€เธ„เธฃเธฒเธฐเธซเนŒเธšเธญเธฅ
                    • Tech Helpdesk
                      • Jul 2015
                      • 112
                      #100
                      I have to ask what are Konica-Minolta UK doing about this ? Probably nothing as usual.
                      Is it specification or a fault lol ??
                      Seriously there has to be a connection issue and a bias drop out, it just needs to be found.
                      I will do some digging and see what I can find.
                      Regards
                      • nicabocca
                        • May 2015
                        • 6
                        #101
                        Hi all, what is your TCR-C % ???????? TCR Level History. I have just had the same issue, I have replaced the following: Print Head, FREYB, PRCB, Dev unit, Drum unit, Toner, inspected and cleaned hopper etc.
                        Reason why I ask for the TCR-C is mine goes down to 0.91% pretty quick, I can manually add tonerand bring it back up to 6.#%, but all our prints are coming out with cyan over everything, except Black only prints/copies. Besides the Vdc-C being 800 and Vg-C 922, everything seems ok.
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2139
                          #102
                          mine was / is staying stable at 6.xx%
                          I was there again today and checked it, 20 something thousand colour pages printed now and still OK - Though I see cyan dusting at the rear of the second transfer roller - FFS!...
                          Today it ran the K toner hopper dry and the toner bottle was empty and coded out with 2557. The toner level sensor in the hopper is FUNCTIONAL too! WTF.
                          Perhaps it was the act of resetting the machine that made it assume there was more toner available than there was.
                          installed new toner bottle, manual toner add developer K twice to bring back to 6.xx% from 0%. Not ideal I know but Ive done this plenty of times in the past without issue.
                          I have ordered the sub hopper assembly and will replace it if it returns.
                          • nicabocca
                            • May 2015
                            • 6
                            #103
                            Within a few colour prints it starts dropping back down. Once it gets under 1% then the C255# error comes up for cyan. Open and close the front door and it resets the code and adds some toner, then I can manually add toner, then all the pages come out covered even worse in cyan for a while. Had this issue before, but was normally fixed with a new dev unit, on a couple machines was the Print control board. Got me stumped this time.
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              #104
                              if its solid edge to edge on the sheet i would be trying a HV board and checking the condition of the HV contacts at the back of the machine.
                              • nicabocca
                                • May 2015
                                • 6
                                #105
                                Its shading within the entire print area of the page covering everthing. Even when I do the gradation test prints from the service mode for each colour they all come covered in cyan over the top of Y/M/C prints, but not the black only.
