C224e/C284e/C364e/C454e/C545e cyan dev unit problems
  • Tech Helpdesk
    • Jul 2015
    • 112
    #151
    Re: C224e/C284e/C364e/C454e/C545e cyan dev unit problems
    This bulletin was recently released.
    It basically says not to let ANY unit run over life & keep the FW up to date.
    Most of my Bizhub users have high expectations so I replace all units before they cause a print quality issue, hence I rarely see this issue.
    [ATTACH]36145[/ATTACH]
    I don't understand why this bulletin was recently released as my bulletin KM UK was dated 25th March 2015 and it is word for word the same as yours. If you were fortunate to be at the Dealer meeting last year KM Japan admitted that you cannot run any of the units over 150% of life.
    With these machines you can get away with a lot providing you replace the drums between 100 and 150% (latest) , TBU at around 100-150%, and feed the machine decent toner and you will be able to reset the units for a second life comfortably.
    • Drcopy
      • Jan 2017
      • 57
      #152
      I have just read all the posts from the start, because one of my techs is now having this issue with the cyan depleting and causing print quality problem.
      Replaced the parts mentioned in this thread and as we speak now updating the firmware, drum life (C,M,Y,K) are below 100% as well.
      Waiting to hear from the tech after the update.
      • Drcopy
        • Jan 2017
        • 57
        #153
        Just recieved confirmation firmware made no difference.
        • copier tech
          • 8136
          #154
          The firmware wont correct a faulty dev unit, the firmware is designed to prevent a future cyan dev failure.
          You will still need to replace the cyan dev unit, or as I do keep the old units, pour out the dev & use it to top out others as they fail, its a cheap option but works very well.
          • Tech Helpdesk
            • Jul 2015
            • 112
            #155
            Good news, Katun are selling developers for the black units now !!!!
              • 14645
              #156
              Now, that's just asking for trouble. Lol
              • femaster
                • May 2011
                • 1492
                #157
                Was thinking the same thing. With as many issues as they have with the OEM stuff, I wouldn't even want to fathom the problems with non-OEM!
                Sent from Tapatalk.
                • rinser
                  • Mar 2012
                  • 9
                  #158
                  Has anyone come to a solid conclusion on what causes these cyan developers to fail?
                  We have a few of these causing problems,
                  On one 224e machine, only the drums were over life and the developer failed at 27k mono 65k colour, the machine was running oem toner
                  We replaced the following:
                  Cyan Dev
                  all drum units
                  High Voltage board
                  updated the fw
                  but the problem returned after 35k again.
                  any ideas?
                  • habik
                    • 2013
                    #159
                    Cyan Dev
                    all drum units
                    High Voltage board
                    updated the fw
                    any ideas?
                    Try vacuuming the ducts and change TX belt + TR.
                    Firmwares HERE
                    • jonbonse
                      • Jun 2009
                      • 737
                      #160
                      Originally posted by allan
                      No problem on my machines. The toner add does not work together it is the same as C360 only change is the reed switches was changed to Photo interuptors because of the developer bieng added to the toner it would get stuck to the magnet inside the sub hopper. Are you reseting the dev tanks? >dealer trick = buy only black Dev tanks and convert to color much cheaper<. The sensors cant see color only density!
                      Can you get colour dev rather than buying the whole dev unit then?
                      • copier tech
                        • 8136
                        #161
                        Not officially.
                        However you can buy after market crap if you want to ruin your machine!
                        • Don N.
                          • Nov 2011
                          • 409
                          #162
                          Not officially.
                          We're having good results with dev from copylite on c220 series. Likely same dev in both series. Same gram weight in bag, used 4e dev in c220 all colors working fine. Some c220 Y overtone/dusting prematurely, like 20k. No resolution there yet. Good drums, ITB not at yield yet.
                          • kmbthk
                            • Aug 2010
                            • 9
                            #163
                            vacuum the toner filter duct before replace new cyan dev
                            • enricocopyline
                              • Jun 2018
                              • 122
                              #164
                              Was the solution found to this problem?
                              • Don N.
                                • Nov 2011
                                • 409
                                #165
                                Originally posted by Don N.
                                We're having good results with dev from Clite on c220 series. Likely same dev in both series. Same gram weight in bag, used 4e dev in c220 all colors working fine. Some c220 Y overtone/dusting prematurely, like 20k. No resolution there yet. Good drums, ITB not at yield yet.
                                Had to switch to Ktn developer. Clite Dv was unpredictable. You can use C220 series in a 4e, just pull out the initial toner with aboout 30 halftones at 255 after setup is complete to get the 4e toner in & the c220 toner out. DV is the same. NOW Ktn has 4e color DV' available as of 1/20... It's more expensive but would have the 4e toner in it already.
