4052ci
  • jakebear
    • Oct 2019
    • 33
    4052ci
    Can the machine's paper usage counter be changed?
    • 23009
    Re: 4052ci
    Sure! When you make more prints, it will increment upwards. Make as many as you want! =^..^=
    • jakebear
      • Oct 2019
      • 33
      Re: 4052ci
      当然!当您进行更多打印时,它将向上递增。随心所欲地制作!=^..^=
      I want to change its counter to 0, how do I do this?
      • PrintWhisperer
        • Feb 2018
        • 473
        Re: 4052ci
        Isn't there an email server you should be hacking?
        Leave the copiers alone
        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • Ropariva
          • 680
          • jakebear
            • Oct 2019
            • 33
            Re: 4052ci
            How to reset the counter to zero?
            • Ropariva
              • 680
                Re: 4052ci
                That would be illegal.
                • justanotherhack
                  • Apr 2015
                  • 74
                  Re: 4052ci
                  Kyocera products allow for a one-time reset to 0, ONLY IF the total count is under 1,000. For instance, usage on the demo floor. Once it passes 1,000 it cannot be reset.
                  • craigster
                    • Apr 2016
                    • 201
                    Re: 4052ci
                    This Thread totally cracked me up!! Needed a good laugh after all these scan to email calls came in!!
                    • Samanator
                      • Sep 2017
                      • 579
                      Re: 4052ci
                      Try this.
                      Get a new from the factory (not a refurbished, not used from another machine)a Main PWB, an Engine PWB, and a Hard Drive. Put those in the machine and see if you have zero counts. If not, keep buying new from the factory and replacing all the PWBs on that machine. Sooner or later you may achieve the desired results.
                      Or keep making copies till it goes back to zero.
                      • Ropariva
                        • 680
                        Re: 4052ci
                        Originally posted by Samanator
                        Try this.
                        • dalewb74
                          • Feb 2018
                          • 1157
                          Re: 4052ci
                          you get zero when you purchase a new copier. otherwise it can't or shouldn't be done.
