We started evaluating our contracts on our desktop units and the supplies of our Kyocera desktop units, especially the Kyocera M5526cdws are losing significant amounts of money. I wanted to see if anyone has noticed that the fields are not nearly as much as the mfg suggests and or that the color supplies are being deminished when printing black and white? Also, if maybe there might be something wrong with these units?
Kyocera M5526cdw toner
We have a lot of these under contract and actually noticed that the color cartridges are being used up quickly even on black and white prints. I guess we can print out a service report to see coverage. I guess I am not 100% sure what is TBA failure?
As for the Kyocera MA3500ci we only have a couple of those in the fields but we also noticed similar results with the MA6635cidnsComment
We've stopped selling Kyocera desktops all together, thankfully, way too many issues at least with this series and the 6635 series, but the m2640 was pretty decent, rarely had issues on those as far as I can remember. It wouldn't surprise me though if you're having issues with yields, those cartridges only last 4k anyway.
Back when we had these, we definitely had a bunch of machines that they only did B/W on, and they would complain about replacing the color cartridges, but it's because of it doing process control so often, regardless of what colors are being used. We pretty much could never use aftermarket toners on anything newer from Kyocera, the machines wouldn't read them.........then again, this model had issues with reading genuine a lot, too.Comment
To maintain color quality, color calibrations need to be done on a regular basis. Yes, color calibrations use color toner, even it you are only printing 100% b/w. There is no situation where color toner usage stops, regardless of what sort of images you're printing.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 1Comment
We noticed increased toner consumption if the machine was set to Text for the exposure. Setting Text/Photo used less. This was on a 7003 machine however.
I believe we went into KFS and pushed Text/Photo to all our machines.
In my opinion the MA3500ci is not worth it. The toners are tiny compared to the MA4000ci and you will pay more in shipping costs vs the cost to go to the higher model machine.Evil will always triumph because good is dumb.Comment
In my experience the 5521 and 5526 are fine machines. They have some short comings with the transfer belt cleaning assembly and the toner feeding systems. With OEM toner and the installation of the spring and pad for the toner feeding solenoids these things have nearly ceased to happen. These models, In my opinion, are far superior to the MA3500ci and similar designed legacy devices. I base this on my experience in teardown, troubleshooting, reliability and just how heavy the dog man thing is. Mostly reliability though, and when I have to carry a loaner in to a customers place, usually for one of those clamshell mofos, it's a 5526.
FWIW👍 1Comment
