4054ci says turn off and on with no error code
  • copierknob
    • Jul 2017
    • 70
    I do not even know where to begin with a 4054ci that says turn off and on with no error code.
  • PrintWhisperer
    • Feb 2018
    • 474
    1) Post a screenshot of the panel message you are getting
    2) Describe the start-up process after the Welcome screen
    3) Post a brief history of the machine from un-boxing
    Do you get a message about something formatting in-between reboots after a recent SSD/HDD replacement?
    Update firmware...
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • Slammers
      • Feb 2019
      • 157
      I let all the magic smoke out of my crystal ball over the holiday weekend.
      In all seriousness, if you give us some more info we may be able to assist.
      I have had a few boot related issues on a 5054ci, but can't provide insight without knowing more.
      Does it have a finisher/AK, Dual headed scanner, punch kit, z inserter, card reader, papercut, FW Version, last known meters, is it new..........
      Did you release the scanner lock, did you remove the tray locks after unboxing etc etc.
      • Lunatech
        • Oct 2012
        • 216
        Stop trying to scan money or documents with counterfeit protection in color.
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 725
          Could be someone copying a check...
          Or it's a network error from a corrupt print job that needs resolved?
          • Ropariva
            • 697
            Is it on KFS? Check the device logs is a good start.
            • copierknob
              • Jul 2017
              • 70
              It was working when I arrived and code c6600 was on the log. Manual says it's fuser related.
              • ATM
                • Apr 2025
                • 50
                Check the fuser unit inside, look for paper wrapped arround the fuser.
                • ntbann
                  • Jan 2012
                  • 631
                  You will need to replace the fuser. Then go into 346 fuser mode and turn it off per kyocera bulletin. The collar on the fuser roller come unglued .
