Taskalfa 3051ci Firmware -any need for an update?
  • dolomike
    • May 2025
    • 8
    Hi all,
    The Taskalfa 3051ci I have has the following firmware installed:
    Software Version
    System : 2N4_2000.004.202
    Engine : 2N4_1000.003.003
    Panel : 2N4_7000.004.202
    Scanner : 2N4_1200.003.001
    I don't think this unit has had any servicing since it was installed, so I'm curious if there are any critical/important firmware releases that should be applied to this machine. I'm happy to keep it as is as everything seems fine, but you never know!
    Thanks!
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    At this point probably not. It's getting hard to get parts for these units.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Ropariva
      • 674
      I had 500 of these machines in the field ten years ago. Exactly none now. Three generations have happened since and they are well obsolete. Don’t upgrade the firmware, upgrade the machine.
      • copier tech
        • 8144
        Originally posted by dolomike
        Hi all,
        Software Version
        Thanks!
        This is a latest available firmware for your 3051ci. It addresses various bug fixes.
        README.pdf
        • ThisPete
          Too old to care
          • Jun 2014
          • 207
          If it has no problems, leave it as is.. don't wake the bear, it might get angry...
            • 23008
            Do you have an issue that needs fixing? If no, then don't awaken the bear.
            • dolomike
              • May 2025
              • 8
              Agreed. I was going to say that in my original post, but thought I'd check if there was something I haven't come across yet. All good then!
              • Mostafa Mostafa
                • 27
                May I get a link in private for that firmwarre please?
                I wish I get an upgrade for my firmware but most none help getting it , Thanks in advance
