M6026cidn color reg
  • Geo
    • 662
    [CQ] M6026cidn color reg
    Hi Kids
    So I have a M6026cidn that is giving me major fits.. The box isn't holding registration . I followed the TB for color registration fix but the it doesn't hold, color registrations starts going out after a couple dozen prints. I don't know if this is helpful but its the m and y colors that are going severely out of wack , c for the most part is holding .The reg is so bad that if you tried to realign the registration without the firmware reset , it will take at least 30 tries..
    I did replace the transfer belt and checked the two belt sensors..
    Any thoughts ?
    Thanks much for the help...
    Geo
  • copier tech
    • 8144
    Re: M6026cidn color reg
    Originally posted by Geo
    Hi Kids
    Any thoughts ?
    Geo
    Did you update the firmware & clean the patch sensors ?
    • KYO_OEM
      • Aug 2011
      • 714
      did you follow bulletin F096?
      Special reset FW needed
      • Geo
        • 662
        Yep several times , two thumb drives with separate firmware..Funny thing , no problem for a several years and then red started failing...
        • Geo
          • 662
          Yes I did and confirmed that the cleaning pad was retracting...
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1885
            Generally it's the primary belt, but if a drum or DV unit isn't laying down the correct density, that will throw the registration off also.
            I do the internal test page to check the density of each color. You could also use Blackcat's test pages that he posted from a flash drive.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
              • 23007
              Like this:
              • tee
                • Aug 2014
                • 79
                I had same problem and it was firmware , brand new transfer belt ,cleaned sensors, and
                performed coarse adjustment then the fine color calibration after the engine reset.
                • Geo
                  • 662
                  Like this:
                  Cat
                  Thanks much....
