KM5050 jams from drawer 2 only
  • copyaction
    • Oct 2007
    • 991
    KM5050 with 2.6 million pages groans then jams in multiple copy from drawer 2.
    Replaced feed rollers in both drawers.
    Swapped #1 feed unit into #2 and problem remained.
    There are 2 pages stuck when it jams, 1 halfway out the fuser and 1 can be accessed from lower left jam door.
  • patrickjlc
    • Feb 2015
    • 225
    Re: KM5050 jams from drawer 2 only
    Try swapping paper cassette too. Do sym 903 and check jam codes
    Sent from my motorola one 5G UW using Tapatalk
    • copyaction
      • Oct 2007
      • 991
        • 30294
        Clutch
        • copyaction
          • Oct 2007
          • 991
          Clutch
          Thanks, have they been known to make a groaning noise when misfeeding?
            • 23009
            It would help to know a jam code. Without that, I can only make a random guess. =^..^=
            • copyaction
              • Oct 2007
              • 991
              I am going back tomorrow, I will check jam code.
              • PrintWhisperer
                • Feb 2018
                • 473
                Inspect middle feed unit gear train for sideways deviation, gear skipping.
                "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
                • copyaction
                  • Oct 2007
                  • 991
                  I had thought about that, but it did not jam a single time from drawer one.
                  • kjg
                    • Mar 2009
                    • 112
                    There is a black feed guide on the vertical conveying unit just below feed where unit 2 paper comes out that can have the tabs break off the edges. It is worth checking to see if they are missing. It too can cause pretty consistent misfeeds.
                    • Samanator
                      • Sep 2017
                      • 579
                      Whenever I can, I print out (or look at) the error/jam log of a machine. One can quickly get some insight into the jamming problem a machine is having.
                      It also allows me to see if the customer is blatantly lying about a problem.
                      Not often, but it does happen.
                      • copyaction
                        • Oct 2007
                        • 991
                        Update, went back with paper drawer 2, feed clutch, black plastic feed guide inside lower jam door.
                        None of those resolved it.
                        Cleared jam counter, got it to jam again with jam04 and jam21.
                        Still not a single jam from drawer 1.
                          • 23009
                          CS-3050, 4050, 5050 Falcon III
                          Misfeeds (Jam J12, J21) from tray #3. Paper is folded over toward the bottom of the stack on the left side of the PF-750. Load paper properly.
                          Misfeeds (Jam J21) misfeeds from tray #3, ledger size. (21.03.0C.01.03) Inadequate pressure on left side door idler rollers. Install two add'l pressure springs at lower vertical path idler rollers in left middle door.
                          Misfeeds (Jam J21) misfeeds from tray #4, legal size. Tray for is incorrectly hard programmed to letter size paper. Go to System Settings > Original/Paper Setup [Next] > Cassette Setting [Next] > Paper Size [Change] > Auto > Inch > OK > Media Type [Change] > Plain > OK > Close x4.
                          Misfeeds (Jam 21) multiple feeds from tray #2. (21.02.86.01.03) Shimmed FSW2 & FSW3 with 1mm mylar shim. Riffled paper in tray #2.
                          Misfeeds (Jam 21) from tray #3. Letter size paper has been printed when ledger was selected. (21.03.0C.01.01) Letter paper has been stacked upon ledger paper in the ledger tray #3. Installed only ledger size paper in tray #3.
                          That's what I've got in the database. =^..^=
                          • tmaged
                            Owner/Service Manager
                            • Oct 2008
                            • 1888
                            IIRC it may be the engine PWB. A bad lift unit would take out the engine board on these models. It was really the only problem they had.
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            Become a fan on Facebook
                            • copyaction
                              • Oct 2007
                              • 991
                              I have seen that in the past but the paper in drawer 2 is lifting and only seems to jam on multiple copies.
