P3155 jams at fuser exit at exactly same position
  • i-have-no-clue
    • Feb 2014
    • 14
    Jams occur at every print or somtimes 30 pages or so are ok then jam at every page again.
    Paper has already left fuser unit about 10 or 15 cm and the leading edge of the paper is already
    at or shortly under the paper exit rollers. Somehow it seems that the paper exit drive doesn't start
    driving the exit roller section. Somestimes the remaining half of the paper gets "concertinaed" by the running fuser unit.
    I think the exit section starts driving shortly before the paper reaches it. I've already replaced the fuser unit, because
    i thought it could have something to do with the exit sensor from the fuser unit but no luck. Same error again.
    Thank you.
  • nathicana
    • Aug 2008
    • 330
    Re: P3155 jams at fuser exit at exactly same position
    Hello,
    Please clean the paper dust from the recessed area just prior to the registration rollers. Also look at the sensor on the underside of the drum unit (registration sensor 2) to make sure it is clean.
    It doesn't take much dust in the reflective area to cause these difficult to troubleshoot jams. Jam 0511, 0519
    It's easy to be deceived into replacing the fuser or the high voltage board but most likely some paper dust is actuating registration sensor 2 intermittently causing this timing related jamming problem.
      • 23006
      A jam code would be helpful. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        username checks out.
        • spw
          • Mar 2015
          • 62
          Unnecessary....
          especially for a relatively newer user.
          • Samanator
            • Sep 2017
            • 577
            Wonder if he uses that name with his clients?
            • spw
              • Mar 2015
              • 62
              You 2 are ridiculous and toxic.. The guy asked a simple question, and black cat asked him for some jam codes. Its that simple
              Instead you insult the person....
              You 2 should not be in the field or in this line of work. Unprofessional
              • chibifozz
                • Aug 2024
                • 1
                I was having these jams, numerous 0511 and one 0519, on a P3155dn and was going to replace the fuser. I came back with the fuser and did some research and found this article from the OP. I cleaned excessive paper dust from the inside of the machine and ran over 100 double sided test charts from the cassette without any jams. Thanks for the help!
