Taskalpha 3051ci Problem with not fusing
  • Doug James
    • Jan 2012
    • 935
    [CQ] Taskalpha 3051ci Problem with not fusing
    Hello, I have been working on this for a long while. This machine ran great then started producing unfused copier. It will shoot out a few good copies the starts getting worse. then occasionally shoots out a few good copies. There is no problem with Black and white copies. Just on color. I replaced the FK 8506 IH and the IH Box assy and the Fuser. Not sure what to replace next. What I have done has had no effect. Any help will be greatly appreciated (Pics Attached) THANKS !!!
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1891
    Re: Taskalpha 3051ci Problem with not fusing
    It's only not fusing the process black areas which are 4x the density of other areas. I'm assuming you're using OEM toner, if not that's where I would start. Also assuming you're using standard 20lb paper ? If that's the case, have you tried bumping up the fuser temp a little ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Doug James
      • Jan 2012
      • 935
      Actually is OEM toner. That was my 1st thought. If Not OEM Some weired toner. But everything checks out. I sure hate to bump up fuser but I'm with you. Not much choice....
        • 23010
        Is it safe to assume that it's Plain paper that it's happening on?
        It's really really unlikely, but I had an intermittent fusing issue a while back ... and this is it:
        First & second pages with heavy coverage exceeding 200% fill draw toner from the paper in two bands 35mm & 13mm toward the center of the page. The following pages pick up residual toner from the fuser, clearing up within 5 pages. The effect is worse on glossy linen "certificate" paper (97gsm), KM-4551ci.
        Cold areas present as chipped areas where heaviest fill is present. Hot areas present as shadow images through areas without fill. Tried IH coil, fuser, increasing fusing temperatures in U161: Warmup > Ready (Center) = 173 [default: 165+8] > Drive (Center) = 177 [default: 170+7] > Wait (Center) = 173 [default: 165+8] > Print > Full Speed Print (Center) = 177 [default: 170+7], decreasing fuser temperatures by 5C on same U161 settings.
        Temporarily enabling Silent Mode minimizes the issue. Set Plain media to Normal2 & Certificate media type to Heavy1.
        Remove 375W battery backup in-line with the copier. Remove additional 375W battery backup on the same line but connected to nothing. Restore U161 fuser temperature defaults.
        • KYO_OEM
          • Aug 2011
          • 724
          did you ever run any adjustments?
          U140? U464? U410?
          What do you see on service status page for coverage last page in case of bad copy?
          Have had several systems with printouts like yours, because of not running adjustments.
          One more time i must ask for U000 data, because 3051 would launched in 2013.
          We do not know the counters or the age of the system and components.
          Does it calibrate or not, does all adjustments would done or not.......this all will be visible on U000/ all
          • dalewb74
            • Feb 2018
            • 1163
            maybe you could share with us mind readers what you have already tried to do to fix this?
            • Samanator
              • Sep 2017
              • 579
              Are you running a heavy paper?
              What are the current setting for U161? The default is 165c for this model.
              Have checked the heat roller for defects or stuff stuck to the belt?
              Have you cussed the machine and kicked the stand?
              Details please on what all you have done and observed.
              • Doug James
                • Jan 2012
                • 935
                So far New Fuser, IH Heater behind fuser, IH PWB and thats it. Going to mess with settings tomorrow Thanks !!
                • Doug James
                  • Jan 2012
                  • 935
                  I sure have cussed it... lol Going to try settings tomorrow. Customer is patient. It does run B&W ok. I did replace with new fuser IH Heater and the PWB. Thats it so far...Thanks !!
                    • 30397
                    Paper paper paper
                    What's the paper weight and type?
                    • Doug James
                      • Jan 2012
                      • 935
                      Paper paper paper
                      Regular 20 LB plain paper (Hammermill) Thanks !!
                      • Doug James
                        • Jan 2012
                        • 935
                        U140? U464? U410?
                        Looks like that has fixed it so far. Seems to run without a problem. I went through the U161 settings and set them to the specs (several were off, Low power was set at Mode 2) I calibrated it U464, Halftone U410 is not completing, I am getting S001 Can't find patch. I tried running patch through bypass and moving it around on glass. Siill no luck. So far so good though. Thought I would get a new transfer belt to sharpen up the patch and try again Thanks for your help !!!
                        • KYO_OEM
                          • Aug 2011
                          • 724
                          Check U465/ Stress for front and rear basic values.
                          There you can see the condition from belt surface.
                          For good/ new one there are values around 2600 for both
                          In case of bad/ broken one the values are less than 2000
                          Also check event log for C76xx hidden calls. You`ll never see C76xx o0n the screen, only logged internal.
                          At least you can compare U464/ Target value against U465/ Bias Calib
                          Target values for CMY are nearby visible in Bias calib after running U464/ calib (BK not identical)
                          If 1 or more are closed together, you know the belt surface is not the problem , if you get a diffenece from 30 or more for 1 or more colors you has to search for the reason.
                          e.g. exchange from the related dv or dk.
                          You also can run test copy in case of U100/ Set AC Auto Adj to "OFF" instead of "ON" (system will work with initial values instead of calculated values) for checking unit conditions.
                          ONLY for testing, you has to set back to "ON" after testing!!
                          • Doug James
                            • Jan 2012
                            • 935
                            THANKS SO MUCH !! I Really appreciate this !!
