Lot of thin streak line_KY 5500i
  • Shin
    • Jul 2023
    • 8
    [CQ] Lot of thin streak line_KY 5500i
    Do any one saw the streak line occurring in Prints?
    I did not replace any parts and perform #140, there are lot of thin streak line occurring on every prints.
    the thin streak lines are random.
    Have any one can help to solve the problem?
  • KYO_OEM
    • Aug 2011
    • 705
    Re: Lot of thin streak line_KY 5500i
    looks like high voltage leakage between dv/dk
    new dv needed i think
    • Ropariva
      • 639
      • Shin
        • Jul 2023
        • 8
        I think so, but there is no Dev available for changing.
        But the situation became normal when I change the MAG DC value from 180 to 160.
        And I also change the Mag Duty from 43 to 68, the Image density decrease....
        So the issue can be solve by change the Mag DC value.
        • Shin
          • Jul 2023
          • 8
          I'm not sure how much K pages for Dev unit.
          But ITB and DUC are new, and the life is within 100K pages.
          • Shin
            • Jul 2023
            • 8
            Update again.
            The issue occurs again when I change the Sleeve Duty from 43 to 68....
            When the Sleeve Duty change, the streak line occurs and disappear.
            • dalewb74
              • Feb 2018
              • 1125
              where is the power plugged into?
              • Shin
                • Jul 2023
                • 8
                Do you mean, what the voltag is?
                If yes, this is US version machine.
                • KYO_OEM
                  • Aug 2011
                  • 705
                  power plug is not related to this issue.
                  Depended to the age from each LLU part, system has to calculate needed internal voltages.
                  If the age increased >>system must increase needed voltage also, this would done by internal calibrations. (depended to U464 values)
                  In case of over aged or broken parts, system can`t calculate the needed voltages anymore and you can get problems like this.
                  Without new dv unit you can`t solve this problem.
                  You can try to set U100/ Set AC Auto Adj from ON to OFF.
                  System won`t calculate anymore, but this will maybe helpfull up to new dv arrived only.
                  You also can get other issue at once.
                  By the way: after each change from any value of U140, you has to recalibrate the system by U464 manually!
