Fuser loose bushes anyone tried Kapton tape?
  • fishleg
    • Mar 2009
    • 426
    Probably everyone on here has replaced fusers with good old 6770 6600 errors because the foam bushes degrade and can't be replaced... had one today I just added a few shims of polyimide tape into the bush and it held. Got a few hundred out couldn't see the harm but I couldn't guarantee it would last long term. I'm going back with a new fuser just a mad light bulb moment had some polyimide tape on me from something else less crazy.
    The fuser I tried it on the bushes so loose machine didn't even warm up but with tape it worked..
    Polyimide tape doesn't melt or set on fire can handle 240c fine.
    Anyone else tried? 4052 4053 fk-8550 type fuser I'm thinking.
    • 23009
    Re: Fuser loose bushes anyone tried Kapton tape?
    It's funny that I've never heard of it. It seems like the perfect temporary solution. =^..^=
    • tec966
      • Mar 2009
      • 42
      great !
      can you send some photos please ?
      • Lunatech
        • Oct 2012
        • 210
        I would like to see what you did and how you used it to make the repair. If you could post some pictures, that would be great.
        • KYO_OEM
          • Aug 2011
          • 721
          I am generally like self made modifications, but not for the FK units.
          Against C6600/ C6770 i prefer to think about U346/ Fuser Power Mode set to OFF or running system with Silent Mode
          By using one of them you can prevent these codes in early stage
          I have had very good experience with this.
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 710
            Our company makes sure that every 52 or 53 series Kyocera has silent mode turned ON to extend the life of fusers. Only had 2 or 3 complain about the speed slowing thankfully.
