ECOSYS P5026cdw - disable printing
  • kuby
    • Oct 2007
    • 1413
    I know that it may not be possible but we had a P5026cdw that was snatched at a show. It is on KFS and I can see it has run out of a color toner. Is there a way to disable the printer?
  • Ropariva
    • 696
    • kuby
      • Oct 2007
      • 1413
      Re: ECOSYS P5026cdw - disable printing
      You can't edit the screen on a P5026cdw.
      • dalewb74
        • Feb 2018
        • 1167
        remove the power cord? disconnect the network connection? setup a private network?
        • Larhal
          • 616
          If you had read the first post he stated that the printer was taken, snatched, at a show. So if he was able to remove the power cord would you not just take, Snatch, it back?
          Larhal
          If all else fails read the Service Manual!
          If that fails, meet me at the pub and we will discuss it.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1900
            I checked one on KFS, there's not much you can do short of changing the IP address. I was going to suggest changing it from port 9100, but that option isn't in there.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • ihatefinishers13
              Senior MFP Technician
              • Feb 2020
              • 724
              You could send setting changes through KFS, disable USB, and change the IP address to be something weird, HOWEVER, then YOU can't get in to it on KFS either, and it will be gone forever.
