6052ci really light copies
  • Samanator
    • Sep 2017
    • 579
    Attached is a sample of issue I am dealing with. When the customer prints out a page with hyperlinks, it's not coming out correctly. It seems that everything that prints out is really light. They are using OEM toner. Firmware is at he latest version. I pulled out all the charger rollers and cleaned them off. I ran laser cleaning. I ran developer refresh a few times as well as a drum refresh then ran Image Adjustment (U464, U469 (had to skip past this), & U410) without any change in the quality.
    Also, before I left, I discovered that the machine would not U469 (registration adjustment) correctly. It keeps giving me SFFF when I do the auto reg. When I tried to do it manually, there wasn't enough yellow on the page to see the hash marks in the blue field. Even using a yellow highlighter. I took it out into the sun and still couldn't see the yellow in the blue field.
    Called Kyocera and was told that it is probably an issue with the main pwb. Is it me, or do all these hotline guys (no matter the manufacture) always say the problem is solved by replacing a board? A discussion for another time.
    When I go back, I will flash the firmware but I don't think that's the issue. I'm also thinking about downloading the settings then initializing the machine as well as running U024 formatting the HHD. Then see if there is a difference. Either way, upload the settings via U917 (cause that's where I got them). I will also be taking a main pwb with me and try that.
    I am welcome for any other suggestions. This machine is not quite at the end of lease and my boss doesn't want this customer thinking about looking around (no pressure, right?).
  • dalewb74
    • Feb 2018
    • 1167
    Re: 6052ci really light copies
    you said this happens when the customer prints? look at the actual quality of the image. when it prints its not gonna be as vibrant as what is seen on the monitor. also look at the printer properties on the PC. maybe if the customer can email you the image and you print it on a different machine. then compare the two. print a black and white image. is it light in that same area? i think its an image issue or settings issue.
    • Samanator
      • Sep 2017
      • 579
      Thank you for your reply dalewb74.
      The day I was there was the day my PC crashed on me so I had no way of printing from my PC to the machine to give me a different baseline.
      I also know the difference between a reflective image (looking at an image on a sheet of paper) and a luminous image (an image on a computer screen or monitor).
      Overall, the machine seems to be printing out stuff real light. Then there's the issue that the machine won't set registration.
      • Scott
        • 198
        Transfer belt?, is it only on prints or does it happen during copying as well
        • Ropariva
          • Mar 2016
          • 693
            • 23010
            I also have seen various HVT issues. Before I did that though, I would try checking the driver checkbox "Print Text As Black". That may improve your image.
            That must be the first thing they teach you on the hotline: "Replace the Main Board!!!" I think the hotline must get kickbacks on the sales of expensive parts, since they always start with the most expensive possibility. =^..^=
            • KYO_OEM
              • Aug 2011
              • 725
              Without U000 data it`s difficult to find any wrong data.
              But i will try another way:
              U469 don`t work and no more good calibrations...
              What do you see in U468/ V-Correction, 65535 or not?
              (decimal data, convert to binare value and you`ll see 16 times "1" for last 16 well running calibrations)
              Compare data from U464/ Target value and U465/ Bias Calib after running U464/calib
              In good condition values from CMY (Target and result) are the same or nearby the same, BK has big difference (this is o.k)
              (density result measured by id sensors)
              Data from U465/ Stress are <90 or not?
              (physical condition from transfer belt surface/ good or NG/ value <90 shows bad condition from belt surface, system can`t calculate needed values anymore)
              (similar to AGC from scanner --> system need basic values for measurement from density patches on the belt)
              If data totally out of target/ new belt needed
              Next i would check high voltages
              1.
              i would start with color belt/ U089 (system is printing with initial values)
              2.
              enter U100/ Set AC Auto Adj from "ON" to "OFF" (to prevent C510x/ no more auto correction for density based on age of parts)
              3.
              remove mc from each drum step by step and check full solid image on drum surface and belt.
              4.
              at least if there is no matter with dk and belt image, check 2nd transfer contacts for oxidation
              Depended to the result check HVT spring contacts on main hvt and transfer hvt pwb
              Finally exchange from hvt board needed.
              If you get full solid image on all colors, you must take care for laser/ laser controlling.
              (have had full yellow color, but no yellow halftone on color belt, without any C4xxx failure in past and new laser unit needed)
              Don`t forget to switch back U100 value!
              Good luck
              • ThisPete
                Snr/troubleshoot/network
                • Jun 2014
                • 238
                In the example you've attached Samanator , the 'pure black' is looking fine, the 'four colour black' isn't very good and is showing signs of registration shift, the text in the middle of the document is showing very bad registration issues..
                The fact that you can't do an auto U469 reflects this, I also think that you are struggling to set the registration manually due to it being so far out in the first place, what happens when you print out from U089 as KYO_OEM asked?
                • Samanator
                  • Sep 2017
                  • 579
                  Sorry I didn't get back on this sooner.
                  Upon closer inspection, I discovered that the machine had ACM toner in it. This was a machine we had not yet replaced all the toner. We had a damaged TA3552ci that we were not going to repair. It never had crap toner in it. So I took all the developer units, drum units, and the transfer unit and put them into the problem 6052ci.
                  When I came to the customers office, I pulled the transfer belt, drum, developer units,and all the toner bottles. I then removed the drive unit (DR-8550) so I could get to the Waste Toner Box and give it a good vac. Although the machine wasn't making a clicking sound, as I vacuumed out that Waste Toner Box, I did encounter a few toner rocks. This is typical when using crap-ass toner especially the ACM brand. I then opened up and all the sub toner hoppers and vacuumed out each as best I could. When you look at those sub hoppers, there basically tubes with a spring loaded door at the bottom that connects with the developer unit. With all that done, I replaced everything I had removed. I then put in the new(er) developer, drum, and transfer belt and loaded the machine with fresh Kyocera toner.
                  When I turned the machine on and did not get any codes, I then went to U952 > Execute > Set Up. This automatically walks me down U464, U469, and U410. When I get to U000 and the rest I just hit the button then stop to go to the next one till I'm finished. I then did a U089 Color Belt and all looked good. I took the machine out of service mode and made some test prints. Looked good. I then had the customer make some test prints and copies and all was well.
                  Got the ticket signed, got my stuff and got outta there. This work was done on 4/26 and I have not heard anything from this customer (trust me, I would have).
