Head Stumper Challenge
  • immortalvegan
    • Mar 2010
    • 14
    [CQ] Head Stumper Challenge
    I've got a 1" wide graduated shadow running the long edge of my copies that does not show on scans or prints of scans. It looks very physical, but how can it be???? If it was physical it would show on the scans also.
    It's a KM 1610FP. ;-]
    HELP!
    Chris
    • 22999
    Have you run a counter page or some other internal print, to determine if its optical or a print engine problem? =^..^=
    • immortalvegan
      • Mar 2010
      • 14
      line is not on any prints. machine reports or network prints. Only copies adf or glass, but not scans.
        • 22999
        Originally posted by immortalvegan
        line is ... only on copies from adf or glass, but not scans.
        Wow! I'm stumped! I can think of possibilities for ADF-not glass, or Glass-not ADF, but not affecting scans? I can't begin to explain that. Maybe an image processing issue... but scans should still be affected. =^..^=
        • immortalvegan
          • Mar 2010
          • 14
          My sentiments exactly.
          • copytechman
            • Nov 2008
            • 929
            Is it twain scan or push (where u can change settings @ the machine b4 sending), not familiar w/this model, but if you try to darken b4 scanning that'll typically make any irregularities show up on a scan too. Just a thought!
            Regards!
            A.
            • tcs04
              FORMER Techie
              • 1183
              HELP!
              Chris
              (RICOH TECH... But...) have you compared auto image density and manual image density modes?
              Some Ricoh machines scan a 1" (ish) band and apply the density to the whole main scan line when in auto ID mode, I have seen what sounds like similar problem caused by this. Not sure if a KM would have the same issue?
              May give you a clue as to the cause.
              Try copying an A3 (Large) sheet, reducing and rotating onto an A4 (small) sheet fed long edge first. Does the problem rotate and reduce? This would confirm the optics / scanner as the problem.
              • immortalvegan
                • Mar 2010
                • 14
                we'll never know now. I cleaned everything under the glass (again) to beyond pristine standards put 'er back together and wala... It's gone.
                Love the suggestions on rotate and reduce!!! Brilliant step!
                Thanks everyone, maybe this thread will save someone else some day.
                • tcs04
                  FORMER Techie
                  • 1183
                  WOOHOO!!
                    • 22999
                    Congratulations. =^..^=
                    • Paper_Jam
                      Expecting a call.
                      • Jun 2007
                      • 101
                      I've had customers lean on the scanner and cause a similar problem, just pull up on the left front and it fixed it.
                      • tcs04
                        FORMER Techie
                        • 1183
                        That would be a Ricoh AF1035 then!?
                          • 22999
                          ... It's a KM 1610FP. ;-]
                          HELP!
                          Chris
                          I'm thinking it might be a Kyocera Mita KM-1610.
                          • immortalvegan
                            • Mar 2010
                            • 14
                            sorry Konica Minolta 1610FP
                            • Evan Fitz
                              First you don't say what the low pressure side is at. Second no amp draw. You are looking at this backwards. The condenser don't do the work it only gets rid of the load. What is the Evaporator doing Pressure, Temp Delta T and compressor amp draw. That is where the load is at. Head pressure will follow evaporator pressure, You don't adjust charge by head pressure alone. What was the Delta T across the condenser? A rule of thumb is 30 deg F Delta T Air enter to air leaving the condenser. Need more Info.
