solid black copies help!
  • blue4fun
    • 19
    Kyocera 4050, copies slolid black whole page,try initialize 906, check main charge and drum unit ok, any idea please help.
    • 22845
    Whar does a U000 Maintenance Report look like? Solid black or normal?
    • just a tech
      • Jan 2007
      • 333
      had a copystar 5050 last week giving black copies and internal prints. thought it was the engine board due to improper volts from connector "yc7"-pin#4 when running maint. mode 100. (main charge on). we put an engine board in and downloaded current firmware. copier worked for a day and started the black copies/prints again. gutted copier and found nothing apparently wrong-- no signs of arcing, no burnt wires, nothing..after working with it for a good bit, i noticed that during the times when i was getting good copy/prints, i could run maint. mode 100 and all sounded good.. BUT- when i was getting black copies, and running maint. mode 100, i would here a high pitched squeel. replaced the drum ass'y(with main charge unit) and problem solved. turns out the main charge unit was arcing internally..good luck
      • blue4fun
        • 19
        thank you for good info guys.
        • nathansipe
          just another tech
          • Aug 2009
          • 122
          same problem
          I have the same trouble on KM-4050. I went last week and found toner covering the front end of the grid, so I cleaned it. Fixed it for a week or so now they have called back. I will try to order a main charge unit if i can and see what that does. More suggestions are welcome.
          Best rule for troubleshooting.
          K I S S Keep It Simple Stupid
          • Craigdumass
            • Jun 2009
            • 61
            Replace the main charge unit, clean the two filters by the bypass, blow out your seperation grid, and you will be good to go for another 100k as long as you have no tiny little pit holes in the drum unit, then you have to throw a new drum in it.
            • HmkPrinterTech
              • Sep 2008
              • 21
              This is a voltage issue with the main charger. A build up of toner will cause a short. About a 50/50 chance a new charger will fix it. Replace the drum if you still have unacceptable output.
              • Craigdumass
                • Jun 2009
                • 61
                I kind of thought that was what I just said, except the toner build up comes from not cleaning out your two dust filters by the bypass, the problem is that heat builds up in the machine and causes the toner to stick to the main charge grid. Hence it starts shorting out.
                Furthermore I am not sure about this website, wether it is plagued with technicians that are not Kyocera or Copystar trained technicians. I have noticed some customers even blogging on this site. I hate helping a dealership that is not an authorized dealer and furthermore I hate getting stuck working on a machine that some fly by night copier technician just got done working on.
                • aabarnes1
                  • Mar 2009
                  • 620
                  black strip on the scan glass
                  Grant me the serenity to accept the things I cannot change.
                  • leroyal
                    Expert on The Obsolete
                    • Sep 2007
                    • 156
                    Why don't you tell us how you really feel?....Lighten up.
                    I know what I know better than anyone else knows what I know.
                    • aabarnes1
                      • Mar 2009
                      • 620
                      DUMASS being the operative word, what happenend with you mf, take it easy, this is a forum for people to HELP each other. I get the feeling that if you had a kalshnikov 7.62 we would have a maysacre on our gd hands
                      • 10871087
                        • Jan 2005
                        • 1144
                        Send them to me, I love billing people.
                        • aabarnes1
                          • Mar 2009
                          • 620
                          I REALLY wanna know what 'fly by night' means?
                          • nathansipe
                            just another tech
                            • Aug 2009
                            • 122
                            I ordered a new drum unit with charger since it only has 140k and is under warranty. The toner is coming from the front seal for the drum. The end of the drum was caked so this should take care of it. If not, it doesnt matter, Im on vacation for 2 weeks for the birth of my first daughter. They can worry about it now.
                            • HmkPrinterTech
                              • Sep 2008
                              • 21
                              Awesome! Grats Nathan!
