Ricoh mp 6055 scanner is missing
  • mindhunter
    • May 2008
    • 146
    Hi everybody,
    I have a ricoh that scanner function is missing.
    Hdd is installed correctly and formated as well,
    Does any body have any idea?
  • mindhunter
    • May 2008
    • 146
    Guys any idea? Is it so rare?
    • lukasha
      • Mar 2025
      • 33
      The scanning app is missing. Can you extract it from the firmware. when i get home i can put it here.
      Lukasha
      • lukasha
        • Mar 2025
        • 33
        I just noticed that you don't have a scanner in the service menu, but you do have a scanner application installed. So the solution I gave won't help
        • Luism
          • Dec 2024
          • 27
          Hello, you have to load all the full firmware again
          • sandmanmac
            • 3981
            x2 on this.
            It's at least the first thing you need to try.
            • Mako
              • Jan 2025
              • 864
              Do a factory reset of the machine.
              • Popolopo
                • May 2023
                • 136
                Try change SP 5-895-002 to "0" and restart. It for scanner application
                • dalewb74
                  • Feb 2018
                  • 1157
                  you have a scanner app listed there. use it.....
                  • mindhunter
                    • May 2008
                    • 146
                    The only solution that helped.
                    • anothertech
                      • 1771
                      I wonder how that got changed. I've never seen one change by itself.
                        • 37533
                        Maybe because with previous models where the SOP either didn't exist or was an add on option it was for enabling/disabling the USB port on the controller for printing.
                        • luca72
                          • Oct 2017
                          • 1784
                          Usually, these symptoms are caused by the HDD starting to fail.
                          "I'll be back"
                          • Popolopo
                            • May 2023
                            • 136
                            Usually, if install new fresh nvram. That setting will switch off. I dont have any idea why for this case.
                            • dalewb74
                              • Feb 2018
                              • 1157
                              what happens if you press the quick scanner icon that shows in your photo?
