Curling Paper
  • laser801
    • May 2014
    • 151
    Curling Paper
    Hey Folks! I'm out in the Mass. Area having lots of issues with curling paper pretty badly... Many clients don't want to hear how the humidity is causing much of this... I go to their office, pop in a fresh ream of paper and "poof" ...The curling stops...Some still skeptical... Is there another fix for this until the fall sets in??? Maybe dehumidifier???Some kind of contraption for the trays??? I tried putting in those little packing bead pouches , but they really don't work very well... Appreciate any help!! Thanks in advance, Laser801 This is mostly on the MP4054,s ...But also on a few of the MPC,s as well...
    Last edited by laser801; 09-01-2022, 08:14 PM. Reason: Didn't mention the Models, Sorry
  • luca72
    • Oct 2017
    • 1784
    Re: Curling Paper
    at least the model of the machine put it ... LOL
    "I'll be back"
    • laser801
      • May 2014
      • 151
      Re: Curling Paper
      Sorry, Mostly on the MP 4054,s
        • 37529
        Re: Curling Paper
        Sounds like a sales person from a competitor is out there trying to sell them something else and saying that the machine they will get does not have problems with humidity. What the sales person is not telling them is that the machine he/she is pushing has anti condensation heaters installed, enabled and included in the price.
        • luca72
          • Oct 2017
          • 1784
          Re: Curling Paper
          Probabili Paper umidity, but of i Remember well, There Is also a bullettin about the roller of exit paper unit, and an output tray "liftablle" option.but now i dont have under Hand because now i at home
          "I'll be back"
          • anothertech
            • 1771
            Re: Curling Paper
            Try lowering the fuser temp 10c
            • apump
              • Mar 2009
              • 160
              Re: Curling Paper
              SP1113 set it to 1 (no curl) this does help. you can actually see it right after making the change. but if humidity is bad enough sometimes just putting a new ream of paper is all you can do, especially here in FL
              • Gift
                • Mar 2011
                • 2459
                Re: Curling Paper
                The paper quality can also affect the curling tendency. If you have a good paper in your shop then leave some realms so the customer can put in the a tray on late friday and do test prints on monday and compare it with his own paper. If the room humidity/temps is too bad that a better paper quality doesn't help then the next step might be a tray heater. Here in EU I expect to see more "curling" calls than usual during autumn since people must save money and energy costs - many might turn down the heating.
                • copier tech
                  • 8170
                  Re: Curling Paper
                  You are in a no win situation here.
                  But if the client will consider using slightly thinker paper this is your only real option.
                  Even cheap 100GSM is better than good quality 80GSM in humid environment.
                  • Larhal
                    • 584
                    Re: Curling Paper
                    I had a customer with the same situation. He was using Niceday paper. Would curl when Dry and worse when Humid. I remembered that paper has 2 different finishes on each side due to the way it is processed. Flipped the paper over and it was reduced by 85%. Could try this t next visit.
                    Larhal
                    If all else fails read the Service Manual!
                    If that fails, meet me at the pub and we will discuss it.
                    • rthonpm
                      • Aug 2007
                      • 2859
                      Re: Curling Paper
                      Have to agree. Convinced several of my accounts to move from 20# to 24# paper. Fewer jams, better output, everyone was happier except their accountants until they got decent pricing.
                      Sent from my Pixel 6 Pro using Tapatalk
                      • progoffice
                        • Nov 2008
                        • 336
                        Re: Curling Paper
                        We don't sell Ricoh, but I'm running into the same paper curl issues. It's always been an occasional issue, but never more so than this year for some reason. Perhaps there are cost cutting measures going on at the paper mills? I've been able to prove to the customer that most of their jamming is paper/humidity related. Humid environments, low print volume and high capacity trays are a recipe for disaster.
                        I've considered looking into cassette heaters, but do these really work and can they have negative results if paper is exposed to heat for a long period of time?
                        • KeviM
                          • Oct 2019
                          • 324
                          • laser801
                            • May 2014
                            • 151
                            Re: Curling Paper
                            Thanks for all the input, Well Appreciated!
                            • laser801
                              • May 2014
                              • 151
                              Re: Curling Paper
                              Thanks !!
