Ricoh MPC3004, weird noise color print not good
  • GeorgeBest
    • Jul 2009
    • 516
    Customer called for bad imaged color prints. (see picture)
    Checked the Dv units, Cyan and Magenta, seems allright.
    When I enter for a "forced toner supple" in SP modus it gives a noise, high sound, loud.
    Never had a problem like this on a C3004 . .
    tonerhoppers not good?
    making a black copy, its allright
    making a color copy, the noise again. .
    someone a clue here
    • 8101
    Re: Ricoh MPC3004, weird noise color print not good
    ​I would start by removing & checking the transfer unit.
    What sort of noise does it make ?
    • GeorgeBest
      • Jul 2009
      • 516
      Its a loud noise, not coming from gears, more a motor
      • Codex
        • May 2008
        • 694
        Check color PCU's... I dont think that the problem is the toner hopper... I had some issues with Mpc2004 and hoppers, no noise, at some point the machine asks for toner, even when its full.
        Inviato dal mio SM-S901B utilizzando Tapatalk
        Memento Audere Semper
        • anothertech
          • 1756
          Try pulling each color drum out a little bit to disengage the drum drive, does one of them pulled out make the noise stop? The developer drive gears on the back of the PCDU tend to strip.
          • davel
            • Oct 2011
            • 1076
            My guess would be 2 dev units
            • Popolopo
              • May 2023
              • 102
              My guess is DVtank got problem. Usually white gear near where toner goes into Dvtank is slightly loose. Unfortunately, there not other solution than change Dvtank.
              • luca72
                • Oct 2017
                • 1677
                Originally posted by GeorgeBest
                someone a clue here
                Thanks in adcance[ATTACH=CONFIG]59938[/ATTACH]
                its happen to me, it's a development group that's about to break up internally, probably the black unit, check rotation manualy
                • RicohBoomer
                  • May 2022
                  • 40
                  If you want to remove the PCDUs from the equation you can screw all the way down to the units, put something(A piece of paper) to keep the front cover door from signaling that it is open.
                  Then go to output check in SP Mode and turn on the drum unit rotation. One for black and one for all colors if I recall correctly.
                  If you hear the noise then one by one pull out the PCDUs as it is rotating until it stops. Or doesn't, in which case you know it isn't the PCDUs themselves at least.
                  You don't have to pull them out very far to disconnected them from the drive motor.
                  • luca72
                    • Oct 2017
                    • 1677
                    someone a clue here
                    I now remembered an IMC a few months ago where the color drums made noise because they were rarely used, try removing the PCDUs, put a little yellow toner on the surface of the drum's with a brush, and rotate the drum cylinder a little with your fingers sometimes of times, back and forth, there is also a bulletin that suggests varying some sp regarding the timing of the waxing bar, for quality issue try to clean the 4 laser glass e run calibration....obviously the result depending for remaining pcdu's life
                    • Gift
                      • Mar 2011
                      • 2444
                      light print with diagonal pattern = dev unit issues indeed
                      • MIGUELMARCHENA
                        • Feb 2018
                        • 179
                        It has happened to me that the internal bushings that go before the sprockets of the developing unit that I sent in the photo with a red circle, are already worn out, they let the developer escape and when they are like that, they generate noise because the sprockets no longer lock together. Well, one turn if another doesn't and there is the noise.
                        I don't know if they sell the bushings but yes you should change, if not, you should change the development unit, I think
                        • GIUBOSS
                          • 1382
                          In my opinion I would do a check-up of the PM counter and if necessary I would also replace the other dvus
                          • GeorgeBest
                            • Jul 2009
                            • 516
                            eventually I've changed all tonerhoppers and DV units M and C.
                            Nothing heard ever from customer, that did it
                            Tnx for reply's
                            • anothertech
                              • 1756
                              Tnx for reply's
                              That's one way to do it I guess.
