Hello folks,
I don't know if this has been covered before, just thought I'd share what I've just tried successfully. Ricoh have made these drums a bit trickier to rebuild, comparing to the MPC3000 drums, so it's almost impossible to swap the cable harness as a whole.
The first thing you need to do is shift two cables, since the black drum has the two crossed (as you can see in the picture) and the color drum has them straight. Just lift the plastic stopper (1) and pull the cables (2). Just change their places.
Second thing is that the RJ45-alike connector on the back of the drum (the end that goes into the machine) is different as well. On the black drum the right side is cornered, but on the color drum it's the opposite. Just grind the left side down, but be careful so you don't brake the connector.
Well that's it guys, hope it's useful!
