arm-450n L4-02 headache
  • DINGO
    • 661
    Hi
    I have a arm-450n that gives me a normal L4-02, but this time i'm whith a great dificult to fix it:
    have described the problem:
    -the codes apear every mornings when the costumer conet the copier the first time, well and i go them and if i insist whit the sm 25-1, after about ten attempts, the copier beguin works and works well every day, do a lot of print and copies whithout problem. Next morning same thing.
    -I already do.
    -first of corse, (i now l4-02 means main motor look), clean and repair the residual sistem, whith replace the pads, gears, do ok.
    -Chek to the developer unit and is ok
    -some thig do ast the ps roller unit
    -unit fuser ok to
    -disasssemble and chek and clean main drive unit, clucths of ps roller and so uuuffffff??
    -after all this the problem is not fix, this same.
    -lastly, i change every units, dv, drum, ps roller, and was the same not fix??
    My question was, may be a main board issue??
    sorry a large coment,
    thanks
    • 23006
    In my experience the L4-02 main motor drive code was illlogically caused by a primary high voltage leak from the high voltage cable that runs through the main drive assembly. The cable is part of the main drive assembly and must be ordered that way. You should have no difficulty installing it, since it sounds like you've already stripped this machine to the frame a couple times already. =^..^=
    • DINGO
      • 661
      Hi Blackat
      This machine is giving me a lot of headaches, including for ex. i can't adjust the sm 50-1(, for found
      a good d point for beguin and the end of the copy.
      Only may be that you said , because i already try almost everythinng.
      thanks friend
      • PhilinFla
        • Aug 2008
        • 13
        I would replace the motor, had to do it several times over the years RMOTP0862FCZZ around $88 retail.
        • DINGO
          • 661
          i,snt the motor, when i fix the problem i post here
          • OMD-227
            The only thing I can add to this, and know of a fix, is L4-02 on a Tiger & Jupiter machine can be caused by the MC unit arching. There is a bulletin on this code appearing during warmup, or first use of the machine each day.
            Replace the MC Unit and test.
            • Toner Boy
              • Aug 2007
              • 365
              If the MC doesn't fix it and the machine has a high meter, I would replace the main drive unit rather than clean it. Too much work done already! Not guaranteed of course...
              • Acadien
                • Nov 2009
                • 17
                the only problem I had with L4 code, on those machine, was caused by the toner cartridge.
                • DINGO
                  • 661
                  thanks
                  hi friends
                  thanks for all coments.
                  The issue was fix, there was a HV leak in the main drive unit.
                  • DINGO
                    • 661
                    re
                    Hi wazza
                    at propose, do you have acess that boletim?
                    can post, or send me??
                    thanks
                    • pcernicky
                      • Feb 2010
                      • 66
                      Do you have any issues with the copy quality? I have drum with perfect black image, but when on the paper grey and missing parts of it. This copier is killing me....
                      • Toner Boy
                        • Aug 2007
                        • 365
                        These machines don't usually have such drastic problems as you describe. Make sure your toner is OEM, your fuser pressure release tabs are in the 'pressure on' position and that your drum and developer are within specs. You can run a sim 25-01 to check your toner reference level, it should be between 90 and 115 most of the time. Only run 25-02 if you replace developer - and if you do - make sure to clean the mag roller - no toner buildup on the surface. Your MC grid and sawtooth electrode need to be clean as well.
                        • mmru4real
                          • Aug 2008
                          • 67
                          the other thing that can cause this is buildup of waste toner on the drum unit, have seen a lot of these and vacuuming out the waste toner usually take care of this, Tigers were known from this, and Sharp just has never done anything to resolve the issue, just fixed 3 of these last week all for l4-02 issues all different customers, the drum unit literally does not turn except for maybe one copy then locks up.
