Sharp AR-235 dumping dev
  • vlad_robas
    • Oct 2006
    • 225
    Hello agaian,
    I don't have all record's about this machine but since i know it it had this problem. It has now 190k at about 100k sombody refiled cartridge then i was called, it had all developer gone thru all copier so i put a new dev and toner. Then afther about 10k was runing low on dev again so i changed the dev unit, but the dev didn't stop spreading thru copier so i go far and replace the drum unit and drum. Afther that quiet till few week's ago when we had to change the poligonal motor, i asked here about the code, and we see again developer all over the place. I have no ideea what to do next. I looked at the 8 values and they seem to be ok. Never done a firmware update on this.
    In attachement is a printed document and it's back which has dev on it.
    • 22992
    The drum unit should have resolved this for you. The drum unit had a new primary charger, yes? That is what usually causes developer dumping on the Gazelle and Leopard series machines. It was more common on the Gazelle (AR-M208N), but in our case we had 5 Gazelles that were too small for the amout of copy volume, all in one building. Are you using OEM developer and toner? I seem to recall reading something about a problem with charge contacts on the door. Wazza, do you have any documentation on this? =^..^=
    • vlad_robas
      • Oct 2006
      • 225
      I'm not 100% sure about the new charging unit but for sure i put clean one back then (i use to reuse them by washing-is that wrong?). The one that i changed these days was realy realy messy, there is smoking in the next office. Should i try to put a brand new MC and a developer?
      PS. this is valuable, i got a reply from the master himself
        • 22992
        Before you change the developer again please run simulation 25-01. What value does it stir at?
        I clean and re-string the wires on those charge units, but replace at 300k copies or when it starts to dump developer.
        Yes, I would replace the primary charge unit and developer, and run simulation 25-2 and 24-05. What stir value do you get? I would expect a value between 90 and 110 for new developer. =^..^=
        Last edited by blackcat4866; 03-27-2010, 06:01 PM. Reason: running off at the mouth.
        • mtech
          • Mar 2007
          • 307
          Check the springs on the right door. I had a lot of these with the same problem. Poor contact causes the developer to be pulled out over about 10-15K copies. There was a bulletin about this issue. I would also check or replace the transfer unit. Depending on the age of the machine, make sure the right door is not warped from fuser heat.
          • vlad_robas
            • Oct 2006
            • 225
            The right door clearly it isn't closing very well and is making a bit of noise, forgot to say that ...
            • OMD-227
              You guys are right. I know its an old bulletin, but it clearly says the issue is caused by the door or the electrode plate in the transfer roller unit.
              Attaching a few images from the bulletin.
              Hope this helps you.
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1865
                We use the 310MC main charge unit. Sharp eliminated some teeth on the ends of the saw tooth that was a cause of arcing. Good stuff here !!
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • vlad_robas
                  • Oct 2006
                  • 225
                  ''wazza'' can u please find a better view of this buletin, i cant see the codes... and i don't want to order something that isn't need
                  PS my dealer sent to me a CD with some of the buletin's but this isn't there
                    • 22992
                    vlad,
                    if you vant to see the documents more closely you can download them to your PC.
                    Right-click on the document
                    Save Target As
                    browse to where you would like to save the document
                    Save
                    Now open the document in Windows Picture & Fax Viewer, and you can enlarge the image enough to examine every pixel.
                    You may have a different application to view .JPG files, but I think you get the idea. =^..^=
                    • vlad_robas
                      • Oct 2006
                      • 225
                      hmm.... i already have tryed that and printed too still can't see good enough .... mostly i understood what should i order but i wanted to be 100% sure if is not to much trouble
                      • OMD-227
                        A better view?
                        • vlad_robas
                          • Oct 2006
                          • 225
                          Much better, i'll update here afther is done. Thank you all.
                          • vlad_robas
                            • Oct 2006
                            • 225
                            Yesterday i did change those spring's and reinforce plate and i put a new developer that gave me 120 afther running 25-2. I hope he won't dump any developer ever again.
                            • rednecktek
                              • Jun 2010
                              • 6
                              This and replacing the seal on the DV unit solves most of the problem for us.
