AR-207 registration
  • jworthington
    • Mar 2010
    • 12
    AR-207 registration
    hello, i have an AR-207 that the reg. is 1 inch off the lead edge. another tech was out yesterday and cleaned the clutch and all was ok. the lead edge does not vary, alway the same 1 inch. any ideas?
    thanks for any help.
  • bilyahn
    • Dec 2006
    • 1470
    Are you using the DF or is it off of the glass? Do you have more than 1 tray and if so is it the same for both trays or the bypass?
      • 22994
      I've got some possibilities:
      Worn registration clutch or registration solenoid, 37mm registration early.
      Worn drum drive gear, variable registration.
      Plastic retaining hooks broke and/or rear transfer grounding spring is missing (usually dropped into the bypass tray), 40mm registration late.
      The last is the most common, by far. =^..^=
      • jworthington
        • Mar 2010
        • 12
        it does is form both the glass and df, and both cass.. got the reg. clutch on order, will know more after that. thanks for the ideas
        • TechGeek
          • 158
          Just an FYI i have had the LFR bushings get gummed up causing the trail edge to be off by about an inch. Double check that it is the lead edge you are having trouble with. if it is the LFR just take out the fuser and clean.
