ARM550 copy quality issues.
  • bdcrandall13
    • Sep 2010
    • 236
    Got another one for you guys...
    ARM550u that prints internally and looks GREAT. Not a thing wrong with the prints whether you run single sided or duplex. When you run a copy off of the glass the copy comes out OK. The copy is a little wavy but as you will see it is much worse when running from the ADF.
    When running copies from the ADF the first side, when running it 1-1 or 2-2 comes out very wavy. I have changed the scan pwb but it looks as if it could be something wrong with the scanner itself. Could the scanner rails/wire be loose? I've never had to mess with any of that so not sure how much tension there should be. I should also mention that this machine is in a beef packing plant and the ground is somewhat shaking form all the machinery running. I don't think it enough to shake the scanner though.
    When running copies 2-2 the second side does NOT come out wavy so I believe that rules out paper movement as the cause. It does leave light copies though. I adjusted the exposure to compensate but it is still lighter than the second side. If I adjust it any more then it picks up the image from the other side of the paper and leaves a dark background.
    I attached some scans from the machine but it won't let me put them in any order. Hopefully i labeled them well enough for you guys to see what I am talking about. If you've got any input i would appreciate it!
    Brooks
    b.crandall@officesolutionsinc.biz_20110216_170330.pdf Test print 70 printed in duplex and then copied. Notice the waves on page 5 (1st side) and light spots on page 6 (2nd side)
    b.crandall@officesolutionsinc.biz_20110216_170224.pdf Copy off og glass 1-1
    b.crandall@officesolutionsinc.biz_20110216_170157.pdf Before adjustments, data print showing copies on side 1 and side 2. Again, page 2 is 1st side, page 3 is 2nd side.
    b.crandall@officesolutionsinc.biz_20110216_170428.pdf Data print before and after adjustments
    b.crandall@officesolutionsinc.biz_20110216_170504.pdf copy 2-2. Pages 1 and 2 are from the original. Page 3 is 1st side and 4 is 2nd side.
    b.crandall@officesolutionsinc.biz_20110216_170410.pdf Copy 1-1 through ADF
  • Dark Helmet
    • May 2009
    • 856
    The wavey part is got to be your optics. It also makes sense why your 2nd side when using the DF is fine because the CIS is fixed in place and attached to the DF frame.
    I would guess your getting vibration and the scanner is jittering. When using the DF the scanner does not move, it just looks straight up.
    Take them your service manual and show the part that says do not place the machine were vibration will be present.
    • bdcrandall13
      • Sep 2010
      • 236
      That is exactly what I thought as well but i find it hard to believe that it vibrates the same every time. I don't think I mentioned this earlier but it is almost always in the exact same spot as well. You can really see it on the Bird test chart on the bottom border about an inch or two from the lead edge. That is almost always exactly in that spot.
      • ZOOTECH
        Senior member of CRS
        • 3375
        If it's happening in the same spot, clean and lightly lube the scanner rails; also check the wire cables for worn areas.
        • bdcrandall13
          • Sep 2010
          • 236
          But it is happening in the same spot using the ADF... When the scanner isn't moving at all. It would make sense if it was a cable or a scanner rail when using the platen, but not necessarily the ADF.
          • ZOOTECH
            • 3375
            Sorry, my mistake, I misread your OP.
            • mojorolla
              The Wolf
              • 2627
              If using the ADF, the scanner does not move along the rails. The light comes on , the page rolls over the glass, but it is not moving. When I see "waves" it is usually slowing down through the ADF or the glass is damaged. Have you tried adjusting dpi or compression? You also mentioned printing then copying the printed original. Are you making a copy of a copy of a copy...etc.?
              • bdcrandall13
                • Sep 2010
                • 236
                If it was slowing down you would see it on the 2nd side as well. If it was on the glass chances are you would see it throughout the entire page more. I have not tired adjusting DPI or compression. Don't know exactly how to do that or haven't ever tried.
                I used both an original and printed original. No defects were on either page.
                • mxm
                  • Feb 2011
                  • 37
                  if possible could you supply examples of TC 71 Grid pattern then copied through df and glass
                  just curious to see if there is a clear fault line through the page
                  • bdcrandall13
                    • Sep 2010
                    • 236
                    Next time I am out there I will try to print some out.
                      • 23009
                      Two possibilities, probably the latter:
                      First, I have been in environments where they had huge punch presses 15 ft away through a wall. You could feel the floor move with every strike, more so when the hits timed to a resonance, and watch personal chachkies shimmy across peoples desks, even falling on the floor. The call was for noises, which is kind of funny since you can barely tell the machine is running over the background racket. The reflector on light source #1 was vibrating on this Canon NP-8530. I dabbed a little silicone between the joints to quiet this "noise" that I could barely hear. It did produce wavy copies, but they never noticed, and there was nothing I could have done about it anyway. Maybe build a shock platform, or move the copier across the street?
                      Secondly, on some Sharp machines I've seen dirty or poorly lubricated scanner rails, such that when the scanner was at the slide read position, light source #1 was teetering on two of it's four little nylon "feet". Just cleaning the rails and lubricating with a few drops of light oil solved this issue. Loose scanner cable might account for this, but it's extremely uncommon on Dragons to have any problems with the scanner cable. You're more likely to have problems if you over tighten the cable.
                      • Toner Boy
                        • Aug 2007
                        • 366
                        Could it be that the doc feeder height is too high on the rear side causing too big a gap between the platen and the feeder guide? This may account for slight wave in copies on the platen glass also. Also, is the ADF squared up on the machine or does it appear skewed on the box at all? Scanner wires and rails would seem unlikely to be a problem but anything is possible.
                        • Troy
                          • Feb 2011
                          • 22
                          That is weird. Same place everytime, on glass or through feeder. Something is moving. Have you checked the ccd to see if it is fastened tightly? Maybe the machine itself has a vibration at a certain time that moves something that has worked loose in the optics. Please let us know if you resolve this.
                          • bdcrandall13
                            • Sep 2010
                            • 236
                            I haven't been back out there yet. I will double check all optics when I do get a chance to go and let you know the results.
                            • mxm
                              • Feb 2011
                              • 37
                              i am thinking the same as toner boy
                              my 1st post was
                              if possible could you supply examples of TC 64-1- 71 Grid pattern then copied through df and glass
                              if there is a clear fault line through the page top 2 bottom dont think it will be doc feeder levelness
                              but if it just happens on the top and the bottom of the copy that was going to be my suggestion
                              levelness adjustment.pdf
