Altalink 80XX Series special Altboot method
  • hnami
    service technician
    • Nov 2023
    • 171
    hello my friends
    anyone can ask a question for special Altboot problem
    I will answer your questions about Special Altboot and dlm encription message on your altalink device
    You can also send your questions via email to the address اhamednami1361@gmail.com and see the answer to the question in this forum
    goodlook
  • hnami
    service technician
    • Nov 2023
    • 171
    Re: Altalink 80XX Series special Altboot method
    Altboot full version is this links:
    AltaLink_C8045_55_ALTBOOT_system-sw103.002.011.14100 - AltaLink C8030 / C8035 / C8045 / C8055 / C8070 Color Multifunction Printer - Xerox for C8045-55
    AltaLink_C8070_ALTBOOT_system-sw103.003.011.14100 - AltaLink C8030 / C8035 / C8045 / C8055 / C8070 Color Multifunction Printer - Xerox for C8070
    AltaLink_B8045-B8090_ALTBOOT_system-sw10300801114100 - AltaLink B8045 / B8055 / B8065 / B8075 / B8090 Multifunction Printer - Xerox for B8045-8090
    you can read this note befor download : https://static1.squarespace.com/stat...x_Firmware.pdf
    Good luck
    • hnami
      service technician
      • Nov 2023
      • 171
      Friends, pay attention if you use full version Altboot
      1- You must make it clear to cws that this is a forced update and cws must ignore all the limitations of the previous versions and perform a forced altboot update. For this method, you must place a forced update command next to the dlm file, which is the method of creating it.
      Perform the following:
      1. Create a top level folder on the USB Flash drive named AltBoot (not case sensitive).
      Forced AltBoot only: Create a file named FORCED_UPGRADE inside the altboot folder.
      This is an empty file and must not have an extension; the AltBoot routine only checks to
      see that a file with this name is present. To create the empty file:
      • Open the AltBoot folder
      • In a blank area of the screen, right click and select “New”.
      • Select “Text Document”.
      • The name “New Text Document.txt” will be highlighted.
      • Type “FORCED_UPGRADE” (the file name is case sensitive) and press “Enter”.
      • A pop-up with the message “If you change a file name extension, the file might
      become unusable. Are you sure you want to change it?” will appear.
      • Click on Yes
      goodluck
      • hnami
        service technician
        • Nov 2023
        • 171
        hello my friends
        i put a two file in cloud spase for you
        first file is a sd card image for altalink c8045-55
        secount file is a hdd raw image for altalink c8045-55
        this images are active disk image "adi" file and you can write this images by active disk image software
        ask your questions in this forum
        • hnami
          service technician
          • Nov 2023
          • 171
          Note that if the hard drive is healthy and has not been cropped or formatted, you do not need a hard drive image, but if one of the above cases occurs, you must download the swup.usb file from the Xerox "GSN" software website, which requires a username and password for this method. you have and only xerox specialists have access to it. I spent a lot of time to find this file, but I failed to find it. If anyone has this file, please share it in this forum.
          This file contains a bootloader that exceract the DLM file on the hard drive.
          • hnami
            service technician
            • Nov 2023
            • 171
            Despite the introduction and notification of the links of the above posts, does anyone still have problems with Altboot?
            Please reply your questions and comments in this forum
            • hnami
              service technician
              • Nov 2023
              • 171
              Originally posted by hnami
              hello my friends
              goodlook
              I will correct the email address:
              Hamednami1361@gmail.com
              • Hassann
                • Jul 2023
                • 89
                Thank you very much my friend you really helping me
                I have problem with alta c8035
                Keep rebooting i tried to forced upgrade but i field
                So I formated hdd and nothing happened so i formated sd and i got an image from another sd and the same problem not solve
                So if i tried the special boot sw well fix it
                Please if you have any suggestion tell me
                Thanks alot
                • Detonation
                  • Feb 2010
                  • 415
                  Correctemundo. I have the Special Altboot for the C8070. It consists of a 'swup_usb' file (83 kb) and a 'swup_usb.C8070' file (zero kb). I'm wondering if I could rename the latter to make it work for the C8030/35 and C8045/55 as well, since the file itself is empty.
                  • adriansto
                    • 2395
                    swup.usd is different for low, mid and high class of machine.
                    • hnami
                      service technician
                      • Nov 2023
                      • 171
                      Thanks alot
                      hi
                      you need to make an image hdd from anoder device or you can download image file from this forum
                      i put image file link in second thread
                      your hdd need to efi.boot files
                      make a forced altboot usb and try make altboot whith two file FORCED_UPGRADE and DISABLE_DATA_BACKUP
                      if this post help you please like this.
                      • hnami
                        service technician
                        • Nov 2023
                        • 171
                        you dont need swup.usb
                        download the hdd image file from this forum i put the link in thread
                        restore image to new hdd and make forced_altboot usb
                        if you dont how to make this pm me.
                        • hnami
                          service technician
                          • Nov 2023
                          • 171
                          you dont need swusb
                          download the hdd image file from forum and make a forced upgrade
                          • Hassann
                            • Jul 2023
                            • 89
                            hi
                            Thanks for replying
                            So i don't need swup_usb or swup_usb.c8030_35 ?
                            • hnami
                              service technician
                              • Nov 2023
                              • 171
                              Thanks for replying
                              No.hdd image is so run your device.after restore image to hdd make forced_altboot whith two file FORCED_UPGRADE & DISABLE_DATA_BACKUP in your usb device in altboot folder i learned in forum how to make this files.
