Altalink 80XX Series special Altboot method
  • hnami
    service technician
    • Nov 2023
    • 169
    #46
    Re: Altalink 80XX Series special Altboot method
    Originally posted by Detonation
    Thanks for sharing that diagram! Now, as for restoring a corrupt SD, I have personally not been able just yet to clone a SD from another AltaLink.
    Hello
    For what device model?
    • Hassann
      • Jul 2023
      • 85
      #47
      Originally posted by hnami
      Hello friends
      In the attached file, I have drawn a diagram that simply explains the special altboot process.
      I hope it can solve your problems friends
      If this post can help you, don't forget to like and thanks
      Thanks for you all
      Problem solved by getting full hdd image and sd image from
      another machine and install full software
      My only problem now in copy and scan from Dadf the image is shift to left
      • hnami
        service technician
        • Nov 2023
        • 169
        #48
        Originally posted by Hassann
        Thanks for you all
        • Hassann
          • Jul 2023
          • 85
          #49
          Sir problem solved already
          Thanks alot
          • Detonation
            • Feb 2010
            • 410
            #50
            Hello
            • big mike
              • Sep 2012
              • 155
              #51
              I am trying the software.
              Select Image to disk, then select your compressed dlm... which one is it?
              I picked the top one and it want to select a drive to reload. It didn't select my usb drive.
              • hnami
                service technician
                • Nov 2023
                • 169
                #52
                C8030. But I’ll try again some day.
                ok.i share a sd card for C8030 Tonight. you can download it and restore to your sd
                • hnami
                  service technician
                  • Nov 2023
                  • 169
                  #53
                  [ATTACH=CONFIG]61680[/ATTACH]
                  [ATTACH=CONFIG]61681[/ATTACH]
                  You have to tick the first one, which means GPT hard drive (the whole hard image must be restored, not just a partition)
                  • hnami
                    service technician
                    • Nov 2023
                    • 169
                    #54
                    HI feriends
                    this link is image for sd card altalink C8030-35 COUNTER 92K
                    C8030-35 COUNTER 92K.adi - Google Drive
                    dont forget like.
                    thank you
                    • Detonation
                      • Feb 2010
                      • 410
                      #55
                      HI feriends
                      dont forget like.
                      thank you
                      Appreciated! I do have plenty of C8030-C8035 to use as a source though, it's just that it hasn't worked up to now. I'll retry when I have time.
                      • hnami
                        service technician
                        • Nov 2023
                        • 169
                        #56
                        Hi everyone
                        Is anyone still having issues with the special altboot?
                        pm in forum please.
                        • hnami
                          service technician
                          • Nov 2023
                          • 169
                          #57
                          OK
                          Keep going, you will definitely succeed, it's very simple. Once you start the first one, you'll be able to get the job done
                          • hnami
                            service technician
                            • Nov 2023
                            • 169
                            #58
                            I don't know how to restore image to hdd in right way can you tell me how to do that pls
                            By the way to tried using another hdd from another machine but i got the same message
                            " unable to decrypt dlm . Perform special Altboot to upgrade the device
                            hi
                            create image from helthy hdd by "active disk image"software and you can restore image file by this software to formatted hdd.
                            • hnami
                              service technician
                              • Nov 2023
                              • 169
                              #59
                              Hello everyone
                              Does anyone know where I can get free cloud space up to 50 gigs?
                              I need it to upload hard drive images of different models, each of which is approximately 17 GB in size
                              • hnami
                                service technician
                                • Nov 2023
                                • 169
                                #60
                                Hello everyone
                                Friends, I need a 20 GB cloud space to share the hard image file of the devices, can anyone help me?
