Altalink 80XX Series special Altboot method
  • hnami
    service technician
    • Nov 2023
    • 168
    #31
    Re: Altalink 80XX Series special Altboot method
    Originally posted by Detonation
    Well, there is even 'software_upgrade' in the file name. The altboot files have 'ALTBOOT' in the file name. The 119.xxx ALTBOOT files are 632MBs in size.
    Hello friends
    I will correct the links of the full version of Altboot 81xx series
    C8130-35 https://www.support.xerox.com/en-us/...content/153831
    C8145-55 XeroxAltalink_C8145-C8155_ALTBOOT_system-sw11401001128800 - AltaLink C8130 / C8135 / C8145 / C8155 / C8170 Color Multifunction Printer - Xerox
    C8170 XeroxAltalink_C8170_ALTBOOT_system-sw11401101128800 - AltaLink C8130 / C8135 / C8145 / C8155 / C8170 Color Multifunction Printer - Xerox
    B8145 XeroxAltalink_B8145-B8155_ALTBOOT_system-sw114.013.011.28800 - AltaLink C8130 / C8135 / C8145 / C8155 / C8170 Color Multifunction Printer - Xerox
    B8170 XeroxAltalink_B8170_ALTBOOT_system-sw11401401128800 - AltaLink C8130 / C8135 / C8145 / C8155 / C8170 Color Multifunction Printer - Xerox
    • Hassann
      • Jul 2023
      • 75
      #32
      Originally posted by hnami
      HELLO
      the full version software 8035 link is in the forum
      At which stage of the work do you have a problem, so I can guide you
      Hello sir
      I did as you told me
      I create Altboot folder and forced_upgrade and disable_data_backup and use dlm fil 471mb
      I tried that with sd image from another machine
      and with hdd formated some time and with hdd image that I download it from your link but nothing change i still have the same problem
      • hnami
        service technician
        • Nov 2023
        • 168
        #33
        Originally posted by Hassann
        Hello sir
        Can you tell me when reload sd & hdd image on new sd & hdd What message do you receive from the device?
        In addition, the two files FORCED_UPGRADE & DISABLE_DATA_BACKUP in the flash drive are case sensitive and must be written in capital letters
        • Detonation
          • Feb 2010
          • 403
          #34
          I've also seen these machine can be picky about the USB stick. Try a different USB stick as well, newly formatted FAT32. You can even try 2 USB sticks, 1 on the front and 1 in the back.
          • Hassann
            • Jul 2023
            • 75
            #35
            I have try it in capital and small letters and don't work
            Always get get this message ( unable to decrypt dlm. perform special altboot to upgrade the device)
            I don't know really what i have to do
            I think the problem in hdd image maybe i do it in wrong way
            I don't know
            • Hassann
              • Jul 2023
              • 75
              #36
              I tried 4 usb and all work well in another machine and upgrade success
              But in that machine i get this message ( unable to decrypt dlm. perform special altboot to upgrade the device)
              • xcopytech
                • Aug 2006
                • 1792
                #37
                You need special swup files and full altboot file (about 500mb) for special altboot
                • Hassann
                  • Jul 2023
                  • 75
                  #38
                  Hello sir
                  If you have these files pls send to me
                  • hnami
                    service technician
                    • Nov 2023
                    • 168
                    #39
                    Your problem is not with the file, flash or software, you have formatted the boot hard partitions, the file SWUP.USB is available on the site of Xerox technicians and you do not have access to it. The best solution for you is to take an image of the hard drive of the same device with the software ACTIVE DISK IMAGE and Restore on your hard drive, this will solve your problem.
                    Of course, it should be noted that when you reset the hard drive, reprogram the device with the same method as you had done.
                    • hnami
                      service technician
                      • Nov 2023
                      • 168
                      #40
                      The files that I have posted the link to are the files of the full version of Altboot. Unfortunately, our friend formatted the hard drive and the boot partition is lost, and he needs the file SWUP. Otherwise, he can take a backup from a similar hard drive.
                      • adriansto
                        • 2383
                        #41
                        You need these files for special altboot. First must write the sd card image file on new 4GB sd card and put this new sd card into machine.
                        You cant use image file from another machine used sd card.
                        If this procedure dont works and presuming the copier dont have another defect the last option is to do altboot from machine pws altboot. That mean you must have pws altboot software.
                        • hnami
                          service technician
                          • Nov 2023
                          • 168
                          #42
                          I'm sorry, but I don't agree with your opinion. There is no need to use a new sd. It can do this with any sd ram of 4 or 8 gig, even if it has been used before. It is only necessary to use the image of a healthy sd card.
                          • hnami
                            service technician
                            • Nov 2023
                            • 168
                            #43
                            Hello
                            Considering that friends send many messages about programming Altalink 80 series devices and most of them have problems, I will try to upload all Altboot problems in the form of a diagram in this forum by tomorrow.
                            • hnami
                              service technician
                              • Nov 2023
                              • 168
                              #44
                              Hello friends
                              In the attached file, I have drawn a diagram that simply explains the special altboot process.
                              I hope it can solve your problems friends
                              If this post can help you, don't forget to like and thanks
                              • Detonation
                                • Feb 2010
                                • 403
                                #45
                                Thanks for sharing that diagram! Now, as for restoring a corrupt SD, I have personally not been able just yet to clone a SD from another AltaLink.
