Altalink 80XX Series special Altboot method
  • hnami
    service technician
    • Nov 2023
    • 169
    #91
    Re: Altalink 80XX Series special Altboot method
    Originally posted by xcopytech
    Try with usb port on back side of machine
    • xcopytech
      • Aug 2006
      • 1794
      #92
      Try pws altboot
      • hnami
        service technician
        • Nov 2023
        • 169
        #93
        • hnami
          service technician
          • Nov 2023
          • 169
          #94
          hello to friends
          is everything ok?
          Does anyone have any questions?
          • hnami
            service technician
            • Nov 2023
            • 169
            #95
            Originally posted by Detonation
            Thanks for sharing that diagram! Now, as for restoring a corrupt SD, I have personally not been able just yet to clone a SD from another AltaLink.
            hi my ferind
            to clone sd card or restoring sd image use "ACTIVE DISK IMAGE" software i put the link in forum that is free to install
            also you dont neet to anoder sd card i puted link of sd card images on forum
            goodluck
            • hnami
              service technician
              • Nov 2023
              • 169
              #96
              active disk image software download link
              • janik123
                • Feb 2024
                • 30
                #97
                What have you done?
                Install full software with special altboot?
                I did but the machine didnt take it and after inicializating software it restarted, then black screen appear u can wait 1 hour and nothing will happen. sd card was flashed with c8055 software, new hdd installed, my guess is could it be faulty pwb?
                • xcopytech
                  • Aug 2006
                  • 1794
                  #98
                  Did you flash SD card with new file from xerox or with image from another machine?
                  What software level have you tried to install?
                  • hnami
                    service technician
                    • Nov 2023
                    • 169
                    #99
                    try replace hdd and perform forced upgrade
                    • hnami
                      service technician
                      • Nov 2023
                      • 169
                      #100
                      i so have de same problem check cpu cooling
                      • janik123
                        • Feb 2024
                        • 30
                        #101
                        hey guys i would apprieciate if one of u could talk to me its better if we discuss this over the phone i will give u my email adress write me there jgira@dd21.sk
                        • janik123
                          • Feb 2024
                          • 30
                          #102
                          same problem with me too
                          • adriansto
                            • 2388
                            #103
                            What software version do you try to reload?
                            • hnami
                              service technician
                              • Nov 2023
                              • 169
                              #104
                              Try first reload 101.xxx version altboot
                              • Ricardo_Reis
                                • 13
                                #105
                                Correctemundo. I have the Special Altboot for the C8070. It consists of a 'swup_usb' file (83 kb) and a 'swup_usb.C8070' file (zero kb). I'm wondering if I could rename the latter to make it work for the C8030/35 and C8045/55 as well, since the file itself is empty.
                                Here are the SpecialAltboot files for the altalink C80xx B80xx family
                                C8070 https://mega.nz/file/5d1WjByb#bAzQtH...Xph13O-NMdUsO0
                                C8045_55 https://mega.nz/file/dZ8QFSDS#JJlyZ4...2mzJokX7cyCi7c
                                C8030_35 https://mega.nz/file/FEcWHBLL#Ivh0DT...O-50XGJIMCZqrM
                                B8045 to b8090 https://mega.nz/folder/EMFSnSSI#hZoI_L7rMepP2T_cpV4yDg
