Altalink 80XX Series special Altboot method
  • hnami
    service technician
    • Nov 2023
    • 168
    #76
    Re: Altalink 80XX Series special Altboot method
    Dear friends, pay attention
    Considering the many emails I receive, I feel it necessary to mention a few points again
    When you receive the message "unable to decrypt dlm perform special altboot"
    1.It is necessary to restore the image of a healthy SD card of the same device model to your SD card. I have uploaded the link of different types of SD cards of different devices in the forum.
    2.You must restore the image of a healthy hard disk to your hard drive.I have also put the link of hard drives of different devices in the forum.
    3.Do not turn on the device before restoring the firmware because your SD card will become unusable and you will have to restore the image again.
    4.You must have downloaded the full version firmware patch with a volume of about 500 MB. I have also put the link of the full version firmwares in the forum.
    5.Be sure to copy the two files "FORCED_UPGRADE"&"DISABLE_DATA_BACKUP" together with the firmware in the Altboot folder. I have also explained how to create the files in the forum.
    6.Now copy the completed Altboot folder to your USB device and connect it to the device.
    7.turn on device Now wait for the upgrade program to run.
    8.If you want to reduce the counter of the device, create an image from a healthy device SD card with a low counter.
    9.To upload or create images available in the forum Use the software "ACTIVE DISK IMAGE"
    10.Software download link https://dl2.soft98.ir/soft/a/Active....rar?1709152344 password for unzip file is"soft98.ir"
    Good luck
    • hnami
      service technician
      • Nov 2023
      • 168
      #77
      • janik123
        • Feb 2024
        • 21
        #78
        i am getting black screen after restart can anyone help me out.
        • xcopytech
          • Aug 2006
          • 1792
          #79
          What have you done?
          Install full software with special altboot?
          • adriansto
            • 2383
            #80
            More informations about what you did to machine.
            What is the error code show on small 7 digit display?
            • hnami
              service technician
              • Nov 2023
              • 168
              #81
              This error usually occurs when the program on the SD card is cropped and the boot files are damaged.
              Use a new SD card or restore an image of a healthy SD card to the SD card of your device
              • hnami
                service technician
                • Nov 2023
                • 168
                #82
                I asked him and he said that the option "u." is displayed. It means that the device is in upgrade mode
                Maybe you know what the problem is?
                • xcopytech
                  • Aug 2006
                  • 1792
                  #83
                  Perform special altboot with full aoftware dlm file
                  • hnami
                    service technician
                    • Nov 2023
                    • 168
                    #84
                    Tried but did not work
                    • hnami
                      service technician
                      • Nov 2023
                      • 168
                      #85
                      • xcopytech
                        • Aug 2006
                        • 1792
                        #86
                        5 replace sd card
                        • hnami
                          service technician
                          • Nov 2023
                          • 168
                          #87
                          5 replace sd card
                          I changed sd card but also error
                          • xcopytech
                            • Aug 2006
                            • 1792
                            #88
                            Did you restore new sd card image to sd card?
                            Did you perform special altboot with full software dlm file and with special swup files?
                            • hnami
                              service technician
                              • Nov 2023
                              • 168
                              #89
                              The device only turned on and not go to boot or reading usb
                              • xcopytech
                                • Aug 2006
                                • 1792
                                #90
                                Try with usb port on back side of machine
