Re: Altalink 80XX Series special Altboot method
Dear friends, pay attention
Considering the many emails I receive, I feel it necessary to mention a few points again
When you receive the message "unable to decrypt dlm perform special altboot"
1.It is necessary to restore the image of a healthy SD card of the same device model to your SD card. I have uploaded the link of different types of SD cards of different devices in the forum.
2.You must restore the image of a healthy hard disk to your hard drive.I have also put the link of hard drives of different devices in the forum.
3.Do not turn on the device before restoring the firmware because your SD card will become unusable and you will have to restore the image again.
4.You must have downloaded the full version firmware patch with a volume of about 500 MB. I have also put the link of the full version firmwares in the forum.
5.Be sure to copy the two files "FORCED_UPGRADE"&"DISABLE_DATA_BACKUP" together with the firmware in the Altboot folder. I have also explained how to create the files in the forum.
6.Now copy the completed Altboot folder to your USB device and connect it to the device.
7.turn on device Now wait for the upgrade program to run.
8.If you want to reduce the counter of the device, create an image from a healthy device SD card with a low counter.
9.To upload or create images available in the forum Use the software "ACTIVE DISK IMAGE"
10.Software download link https://dl2.soft98.ir/soft/a/Active....rar?1709152344 password for unzip file is"soft98.ir"
Good luck
Good luck
