Altalink 80XX Series special Altboot method
  • Dimitris4
    • Apr 2025
    • 10
    #211
    Originally posted by Hassann
    Hello everyone
    I Got this message when I try to install firmware
    Any advice
    Thanks in advance
    maybe wrong files
    • Hassann
      • Jul 2023
      • 85
      #212
      Thanks for replying
      I Tested the usb and sd and hdd in another machine and worked worke
      • hnami
        service technician
        • Nov 2023
        • 169
        #213
        Hello everyone
        Any advice
        Thanks in advance
        Hi
        Use correct sd card.that is dos not correct.for example you used c8055 sd card for C8070 device.I found sd card image in specialaltboot.com
        • Hassann
          • Jul 2023
          • 85
          #214
          Hello
          I Got that message even when i swiped sd from working machine
          • Marcos Abrantes
            • 1
            #215
            Originally posted by hnami
            Re: Altalink 80XX Series special Altboot method
            hello my friends
            i put a two file in cloud spase for you
            first file is a sd card image for altalink c8045-55
            secount file is a hdd raw image for altalink c8045-55
            this images are active disk image "adi" file and you can write this images by active disk image software
            ask your questions in this forum
            Olá, boa noite!
            Pessoal
            Tenho algumas dúvidas aqui sobre estas imagens, também serve para o modelo C8070?
