C454e "TPM chip has been changed"
  • filladefilla
    • Apr 2024
    • 45
    #61
    yes, please, the original MFP and SSD is installed.
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5825
      #62
      have you tried the reset fw with the hdd unplugged?
      • filladefilla
        • Apr 2024
        • 45
        #63
        No, please, will try that in the morning and provide feedback.
        • filladefilla
          • Apr 2024
          • 45
          #64
          I have tried it this morning... same issue occured.
          • filladefilla
            • Apr 2024
            • 45
            #65
            I removed the SSD from the machine and inserted it into same machine.
            1. I realised that there is no English Language in the list of languages at the Utility settings.
            2. No password is working for Tech Mode
            • filladefilla
              • Apr 2024
              • 45
              #66
              I have been able to bypass D390 by God's Grace.
              I have tried changing the language using Tech mode and Utility settings but there is no English Language in the options.
              Please help.
              Thank you all... especially Synthohol
              • filladefilla
                • Apr 2024
                • 45
                #67
                Even though us is selected in Tech mode yet language appears in Japanese or different language.
                • filladefilla
                  • Apr 2024
                  • 45
                  #68
                  good day.
                  Please I am still having trouble changing language to English.
                  Please help!!!!
                  • Synthohol
                    • Mar 2016
                    • 5825
                    #69
                    service mode. system 1, marketing area, select US. if no fax, fax should be set to OT same with wireless lan if any.
                    7. UTILITY (USER SETTINGS)
                    7.1 System Settings
                    7.1.1 Language Selection (1) Use
                    • To select the language on the LCD display.
                    • To change the language used on the control panel.
                    (2) Procedure
                    • The language as a default depend on the marketing area selected in [Marketing Area] available from [System 1] under Service Mode.
                    I.12.14.1 Marketing Area
                    7.1.2 Language Selection-Panel Keyboard Language Selection
                    (1) Use
                    • To set the language used in the keyboard displayed within the panel.
                    • When using the keyboard language different from the panel display language, you can select from the 9 basic languages.
                    (2) Default setting
                    • Panel Display Language Synchronize
                    (3) Setting item
                    • “Panel Display Language Synchronize”
                    • Panel Display Language Desynchronize
                    and finally in some admin system menu...
                    8.23.7 Temporary Change Language Setting
                    (1) Use
                    • To select whether or not to display the [Language] key, which is used to temporarily change the language for the control panel, on the top
                    screen in each mode.
                    • The temporarily enabled language is returned to the language configured in [User Settings] after any of the following operations.
                    • Main power switch
                    ​hope something helps, i think i can help with movie data too
                    • filladefilla
                      • Apr 2024
                      • 45
                      #70
                      7.1 System Settings
                      (2) Procedure
                      (1) Use
                      (2) Default setting
                      (3) Setting item
                      (1) Use
                      • Main power switch
                      Please I have already done this as in the Service Manual, yet language still remains in Japanese.
                      Would be glad if you could send me Movie data.
                      Thank you.
                      • filladefilla
                        • Apr 2024
                        • 45
                        #71
                        At the utility level, ENGLISH LANGUAGE is taken out of the list of languages....that's the issue.
                        at the Tech mode I have selected the languages as stated in the manual yet the language still remains JAPANESE.
                        Thank you.
                        • Synthohol
                          • Mar 2016
                          • 5825
                          #72
                          marketing area is set to US?
                          • filladefilla
                            • Apr 2024
                            • 45
                            #73
                            YES, PLEASE
                            • filladefilla
                              • Apr 2024
                              • 45
                              #74
                              Language set to US
                              • filladefilla
                                • Apr 2024
                                • 45
                                #75
                                At long last... my Konica Minolta c454e is working normally by God's Grace.
                                I re-applied the firmware and the language has reset to English.
                                Synthohol I really appreicate your suport throughout the entire process
                                You are such a genius.
