c454e fuser 220 volt or 120 volt?
  • adecanmin
    • Oct 2010
    • 316
    Gentlemen.
    I purchased a fuser for a good price. The box says it is for 110v. The lamp terminal has 4 wires coming out of it. From memory (don't currently have that model in the shop) I thought that connector was 3 wire for 120v. If it is 220v would I need to swap the lamp out to get it to work in the 120 volt machine? Or could I plug it in as is and it will work?
    • 30306
    Re: c454e fuser 220 volt or 120 volt?
    Originally posted by adecanmin
    Gentlemen.
    Fuser are voltage specific 120v machines North America , 220v machines other
    Usually the pins will not be in the correct location to prevent accidents
    No they are NOT interchangeable
    If your Fuser is make for 110v it will work in a 120v machine
    • Synthohol
      Certified Konica Expert
      • 5849
      100v fuser (JAPAN) A4FJR70222
      120V FUSER (USA) A4FJR70322
      220V FUSER (EUROPE) A4FJR70422
      THE LAST 2 DIGITS WILL BE HIGHER WHEN NEW REVISIONS ARE MADE.
        • 23009
        It's very easy to order the wrong voltage fuser. I've had a couple "fix-it-myself" customers substitute a 220VAC fuser. I try to explain that I cannot just swap them for a 120vac fuser, and have no use for a 220vac fuser. =^..^=
        • copier tech
          • 8176
          Gentlemen.
          What is the part number on the box?
          • adecanmin
            • Oct 2010
            • 316
            No number on the box. There is one number on the fuser itself. It is a bar code. A4F JA723F0054678. I got a good deal on it so if it is 220v I can still use the parts on it.
              • 30306
              IF YOU bought in the US 99.9 its 120v
              Easy check look at the old one
              • adecanmin
                • Oct 2010
                • 316
                Unfortunately I bought it overseas. I'm not going to lose any sleep over it.
                • femaster
                  • May 2011
                  • 1514
                  If you have no qualms with scavenging parts off of it, you could always spend a little extra time and just swap out the bulbs from an old 120V into that one, the harness connector will swap with the bulbs.
                  • adecanmin
                    • Oct 2010
                    • 316
                    I taken a few apart to change that pesky bearing that wears out. Not too many more steps after that to get to the bulb.
