BH227 Drum Unit melt
  • dibyendu2008
    • Dec 2011
    • 27
    Dear friends I had a problem on BH 227 machine. In this machine Drum unit melt by over heating. Please see the attached images for the problem. Please suggest further what to do.
  • Synthohol
    Certified Konica Expert
    • 5846
    RUN
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      Wow! not sure how it could get that hot and not throw a fuser code. I know that model is Konica Minolta's "ugly stepchild" and wasn't their best design. Not many sold by the dealers I know. With that being said something is missing, there has to be more to this story????
      If it was me I would light fuse and get away!
      • dibyendu2008
        • Dec 2011
        • 27
        No error Is showing for over heating. Please suggest
        • tsbservice
          Field tech
          • 8020
          What about your fuser?
          Anything else near drum melted?
          • Synthohol
            • 5846
            if it melted like that without any codes then that machine is an insurance and safety risk, im sorry but there is no way i would ever leave that machine unattended for a second if that melting damage happened during its use.
            • dibyendu2008
              • Dec 2011
              • 27
              No Sir. Only Drum Unit melt. We use original Drum Unit.
              • dibyendu2008
                • Dec 2011
                • 27
                Sir this is a new machine. I had Replaced first Drum unit for melting that time machine total counter was 5525. Again after 1500 copies Drum unit melting again without showing any error code. Iam surprised. And for your kind information we use original Drum Unit. Last time I decreased the Fusing temparature at -10 in service mode but it will not work. Please share any check point suggestion.
                • Synthohol
                  • 5846
                  if its new then place a warranty claim, seriously even on a copiers worst day it shouldnt melt inside from its own heat.
                  if its new then you really shouldnt even try to fix it you may void the warranty.
                  the plastic melts at around 300F+ and paper catches fire at 415F. i cant imagine how much heat that fuser must be giving off to affect something BELOW it.
                  good luck, this is bad situation.
                  • tsbservice
                    Field tech
                    • 8020
                    Something fishy may happen here I never seen anything like that. Is this client problematic. Maybe someone helped with that drum damage and want to blame machine and service 😞
                    • dibyendu2008
                      • Dec 2011
                      • 27
                      No sir customer is very helpful and friendly
                      • dibyendu2008
                        • Dec 2011
                        • 27
                        Customer had another BH 227 machine in same office. I have already interchange the Fusing Unit but no luck. I think power supply or MFP Board faulty.
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4718
                          What about the enviroment the copier is in, is it extremely hot? Could the fuser exhaust / cooling fan be blocked, if fan not working would throw code. Did you try changing any of the power settings, sleep mode, etc? We usually turn off sleep on all Kon/Min models but in this case I would turn sleep on and if customer is low volume have go into low power / sleep ASAP like 1 or 2 minutes.
                          • copier tech
                            • 8169
                            Maybe you have a failed fuser fan or blocked air filter.
                            • Ziggy
                              • Feb 2018
                              • 768
                              Not sure if this machine has any filters. If it does they may be clogged not letting heat to vent properly
