Konica Minolta Bizhub C224
  • Duhstracted
    • Nov 2024
    • 16
    is there a way to test if it is the yellow developer?
    • Ziggy
      • Feb 2018
      • 733
      In Yellow?
      If yes try cleaning the laser slit glass with the wand in the front door. If you still have problem with yellow then you may have a yellow developer unit problem. If that is the case its time to call your tech back out.
      • Ziggy
        • Feb 2018
        • 733
        You would have to pull the yellow developer unit. I don't recommend this for a user. You can cost yourself more if your not careful
        • Duhstracted
          • Nov 2024
          • 16
          #19
          Thank you so much for all of your help.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4707
            #20
            No one here commented on the invoice. 8 hours labor @ $90 per hr to install a transfer belt, drum, & developer unit. Something is wrong here. That work should take less than 1 hour. You have to tell the tech he fixes the machine for no additional charge or you don't pay the original invoice! If a tech can't diagnose that issue within 1 hour he doesn't know what he is doing, and you should call a different tech. I hate this type of crap, it gives all us techs a bad name. Plus that is a 15 yr old copier, why would you put $1500 into that old machine. You could get a newer C258 for around $2k.
            Show the tech this post if you want to.
            • Ziggy
              • Feb 2018
              • 733
              #21
              I was focused on the copy quality issue but you are correct on the amount of time it should take and the age of the machine . I also just noticed they charged a shipping and handling fee. Don't know why that would be done either
              • kingarthur
                • 1358
                #22
                I've just got to this post, I was also wondering how any half decent tech can spend 8 hours on a machine. Should never spend more than an hour diagnosing and fitting those parts
                  • 23008
                  #23
                  Try these patterns:
                  70% cyan image will not present the issue, but 11% cyan may. It's the 5% to 11% fill images that show finer quality issues.
                  • Duhstracted
                    • Nov 2024
                    • 16
                    #24
                    Try these patterns:
                    Here are the test pages. The scanner isn't do them appropriate justince but I think you van get the idea
                    • danbb
                      • Jul 2021
                      • 6
                      #25
                      Did you still have the magenta and yellow drums swapped when you printed these?
                        • 23008
                        #26
                        IMG_0655 tells the whole story. in the 30% bars crossfeed you'll see distinct voids in black, cyan and magenta. Same voids can be seen even better on the individual 11% color pages: IMG_656, IMG_0657, IMG_0658. Causes for these voids can be:
                        * optical - dirty slit glass, fuzz obstructing the laser optical path (in the drum unit), dirty laser mirrors.
                        * charge - contaminated grid and/or charge wire. Problem can be moved to another color by swapping drums.
                        * drum - wear. Problem can be moved to another color by swapping drums.
                        * developing - observe the developer brush on the developing roller. Voids on the developing roller are caused by contamination under the doctor blade.
                        It can be any of these. Taking photos was a good idea.
                        I just dumped a lot of technical jargon on you. Ask more questions.=^..^=
                        • Duhstracted
                          • Nov 2024
                          • 16
                          #27
                          We have moved the drums and the problem did not get better. I believe that you clean the silt glass with the wand that stays inside the machine, this has also been done several times and now I need a new wand cause the tech guy all but killed it. I can order another and try that. How would I observe the developer brush on the developing roller? You aren't anywhere near San Rafael are you?? lol This has been more help than the $1500 and I got a cool picture of the ventruvian man!
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4707
                            #28
                            You can buy just the pad for the cleaning wand. If that wand has sticky goo on the pad that can get on the laser windows which can cause print quality issues. Sounds like the tech you had was stupid enough to have used it that way and probably have sticky glue on one or all four of the laser windows.
                            Still curious about the 8 hours labor. Can you elaborate on that? Was he there for 8 hours straight, etc
                            • Duhstracted
                              • Nov 2024
                              • 16
                              #29
                              I will get a new pad for the wand. He was here two seperate days... maybe 4 hours each day or maybe he charged me travel time. I would have less issues if the problem was actually corrected.
                              • Duhstracted
                                • Nov 2024
                                • 16
                                #30
                                However, this problem was happening before he came out and ruined the wand. We were having the issue which is why we called him out in the first place.
